Thread: Another newbie that needs help!!
    May 2016
    Reeseville
    2
    I recently just put up an Intex 15' x 48" pool for the kiddos. I filled it with my tap water and having a hard time getting it clear now although it started out clear. I probably should have come here first. I added about 5 1" chlorine tabs to a floating dispenser to start and now the pool is green and cloudy. Ph was high so I added Ph down to fix that. I added about 30oz. of liquid shock (12.5%) and 8 oz of Clorox Algaecide today and then tested the pool about 3 hours later
    with the HPH 6 way tested and came up with the following readings:
    Ch Br: 5 10
    Ph: 7.2
    TA: 22
    Hardness: ??? (Couldn't get test to function properly...water wouldn't turn red)
    CYA: Basically 0. Filled the whole tube and could still see the black dot fine.
    I need help!! How to I clear this thing up?? I just ordered an Intex 2800 sand filter pump to replace the junk 1000 gallon cartridge filter it came with. Do I need to add more shock?? I'm guessing the green is algae, correct??
    Thank you in advance to you all!!!
    Jun 2014
    15,212
    Re: Another newbie that needs help!!
    Welcome to TFP! First thing I have to say ... add nothing else to your water other than regular liquid bleach. Absolutely no more store chemicals like algaecides that add metal to your water. You need a proper test kit. See the TF-100 test kit below in my sig. The HTH is fine for pH, and maybe some TA and CH levels, but beyond that it get dicey, and it will never test chlorine higher than 5 ppm which you need right now. So #1 priority is to get the TF-100 (XL Option with Speed Stir). Post those results and we can help.
    Also, remove those pucks right away. The chlorine they provide does not matter when they add stabilizer which could be throwing-off your readings. Read the SLAM page (link below) and Pool School while you wait for the proper test kit to arrive. Post those numbers and we can help. Nice you have you with us.
    May 2016
    Reeseville
    2
    Thank you for replying. How much bleach do I add?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,584
    Here is a link to the do all of the math and such for you! I love this link BUT it takes some playing with to get used to:
    http://www.troublefreepool.com/calc.html
    Kim
