Thread: Is PoolMath 'stabilizer' CYA or trichlor?
    Mar 2016
    Bakersfield, Ca
    20
    Question Is PoolMath 'stabilizer' CYA or trichlor?
    In the PoolMath CYA section, to go from 0 to 40 it says "Add 64 oz (4#) by weight or 67 oz by volume of stabilizer"
    Is that pure CYA, dichlor, or trichlor? The reason I ask is I just emptied and refilled to lower my CYA, added about 2-3# of CYA to a ~12,000 gal pool, and the CYA level now reads ~50 (dipstrips) so I have a higher CYA than I expected.
    Trichlor only contains about half CYA by weight, but pure CYA is pure CYA.
    What is the PoolMath calculator based on?
    Thanks for running a great forum!
    12,000 gal concrete IG, Sta-Rite MaxEGlas 3/4 HP pump (230v 8A) Sta Rite System 3 Filter, Hayward Ultra crawler.
    10% Bleach bottles on bottom of pool. AquaChek 7 Strips, Clorox SmartStrips, Bakersfield City water.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Is PoolMath 'stabilizer' CYA or trichlor?
    That much CYa in any form. That's kinda like saying you can have 3 ounces of alcohol per day. Whether you choose to drink PGA, beer, wine or whatever------only difference is the ALCOHOL content by volume.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    It is based on CYA sold as stabilizer. Trichlor and dichlor do add CYA. Play with the part at the bottom of pool math where you can calculate the effects of adding different chemicals. That can help you determine how much CYA to stabilized chlorine products will add.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    That's pure granular CYA.
    If you intend to use Trichlor, scroll down to Effects of Adding Chemicals in poolmath and see what 16 oz of Trichlor will do to your pool (Set the volume first) Then work off that to figure out how much you need. Remember Trichlor is very acidic.
    Mar 2016
    Bakersfield, Ca
    20
    Thank you all! I have pure granular CYA.
    Suggestion for the forum- Add a chemical levels default to the entry screen, or make it one of the formatting tools to paste into the post:
    FC
    TC
    CC
    Temp
    CYA
    pH
    TA
    CH
    Borate
    Water Clarity
    So newbies will remember to post their #'s!
    FC 3
    TC
    3
    CC
    0
    Temp
    75
    CYA
    40
    pH
    7.6
    TA
    120
    CH 220
    Borate
    38 (calc)
    Water Clarity
    Crystal w sl surface debris
    I have 25# CaCl on order.
