Results 1 to 10 of 10
Thread: any tricks to disolving granular stabilizer/conditioner?
    Mar 2008
    Delaware
    40
    it's taking me forever, and no matter how long i stir it in the bucket, it's still granular.
    any suggestions?
    Thank you in advance for your help.
    Noctiss
    Mar 2009
    Macon Ga
    77
    Re: any tricks to disolving granular stabilizer/conditioner?
    I just put it in my wifes nylons and tie them in front of a retun. I would go out and shake it every few hours.
    18X38 Grecian 26000 gallon In Ground Vinyl. Goldline AuqaRite SWG with a 1.5 HP Pentair Pump. Triton 2 Sand Filter Two main drains with 4 main returns with 2 more returns on the swimout and two skimmers. Polaris 380
    Butterfly's Avatar
    South Carolina
    10,045
    I put mine in a sock and put it in the skimmer basket. I only add about 1# a day tho.
    You're done SLAMing when:
    Casey's Avatar
    SW PA
    10,453
    I put mine in DH's socks and tie it off with a hair tie and manipulate it over the return til it's all gone.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by Butterfly
    Ditto, 'cept I use a nylon knee high and tie it off so it's not sitting in the skimmer basket itself. I'm a'feared of it blocking the water iff'n it does that.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Jul 2007
    Sahuarita, AZ
    278
    Just dump it into the skimmer and let it go into the filter where it will dissolve at it's own pace.
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    Mar 2008
    Delaware
    40
    Quote Originally Posted by EskimoPie
    i was worried that it would get trapped in the DE and dissolve too slowly.
    thank you all for your responses and suggestions
    Noctiss
    Guest
    Quote Originally Posted by pairadocs
    This is how the instructions on the bottle of most brands of CYA read...to pour it slowly into the skimmer with pump running. I would run the pump 24/7 for the first 48 hours to speed the dissolving and don't clean the filter for a week. It can take up to a week for it all to dissolve no matter how you do it. Nature of the beast.
    Mar 2008
    Delaware
    40
    Quote Originally Posted by MikeInTN
    i did the nylonknee high trick, soaked overnight, and then checked it this am - not alot gone, but i managed to squish it for a few minutes and dissolved 90% of it into the skimmer. worked great.
    thanks all
    Noctiss
    Mar 2007
    San Rafael, CA USA
    12,082
    I took an old men's undershirt (though a skimmer sock or panty hose would likely work just as well) and put the Cyanuric Acid (CYA) on top of it in the skimmer basket and kept the pump running continuously on higher speed (48 GPM overall). I have floor drains as well as a skimmer and my skimmer also has a bypass pipe into the pool so it won't get damaged even if it gets clogged. The CYA dissolved overnight in less than 12 hours. My CYA readings showed at least 2/3rds or more of the expected amount (which at 30 ppm is within test error).
