Results 1 to 7 of 7
Thread: Bottom drain while slamming
    lovestoswim's Avatar
    May 2015
    Milford, Ohio
    102
    Helping a friend with their swamp and he asked if he is supposed to do anything to the drain at the bottom of the pool? Also his ph was 6.8 . Do we keep slamming or should we get ph up?
    24,000 gallon, 21x43 Oval Wilbur AGP installed June 2015. 10'X24' deck. 2hp Aqua Pro Cartridge Filter. Using TFP method.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: Bottom drain while slamming
    The bottom drain should help with circulation during slam. On the PH......did you adjust to 7.2 before going to SLAM chlorine level?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    May 2015
    Milford, Ohio
    102
    We did not adjust ph. FC was at 3.0 pool store told him to just vacume and not add any chemicals.... So I told him he needed to raise FC to 15 & keep scrubbing.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    I'd leave it open. With any luck, when you brush, the stuff will find its way there and get whisked off to be filtered away.
    The pH should be higher. Low pH can be hard on plaster and metal components, especially heater cores. But the pH test is no good with FC above 10, so you'll have to let FC drop some to test it.
    May 2015
    Milford, Ohio
    102
    Darn! FC was at 3.0 with ph at 6.8 at first test..... I told him to start shocking. I should have raised ph. So should I stop slamming?
    Richard320's Avatar
    Jan 2010
    19,009
    Quote Originally Posted by lovestoswim View Post
    Sent from my Z959 using Tapatalk
    Actually, if you're confident of that pH, you can use it to figure it the adjustment dose now and add it. You just won't be able to retest pH for a while.
    May 2015
    Milford, Ohio
    102
    OK thank you Richard!
