Results 1 to 9 of 9
Thread: CYA Level?
    Mar 2016
    York,Pa
    18
    CYA Level?
    The skylight in my signature is centrally located over my pool (2ft over 14ft pool length, 4ft over 6ft pool width, recessed 21 in. above pool room ceiling, ceiling 64 in. above water level). The amount of sunlight that hits the water is dependent on the time of year and day when I am using the pool and for how long, typically 30 minutes per day. Assuming that the pool cover will block sunlight from impacting the chlorine, what CYA level would you recommend?
    Endless Pool Owner, since April 2015, 6 ft by 14 ft , 51 inches deep, 2677 gallons
    AG, indoor; 2 by 4 skylight, always covered with solar pool blanket when not in use, temp at an indicated 85, Taylor K
    Delta EA-4H UV Sanitizer, inline with circulating pump
    Pleatco PWW50L cartridge filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: CYA Level?
    I'll suggest 30. You can't really even read lower than that with some testers. You'd never know if it was all gone.
    With 30 CYA and hardly any sunlight, your chlorine losses should be laughably small. You'll be dosing with a teaspoon.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: CYA Level?
    The skylight itself will block a large portion of the UV spectrum.
    chiefwej
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: CYA Level?
    I agree that 30 is best because it is measurable. And there is no downside to 30.
    Mar 2016
    York,Pa
    18
    Re: CYA Level?
    Given my profile description and vinyl liner, one person using it for 30 minutes a day, what would be your recommended levels, with the CYA at 30?
    Richard320's Avatar
    Jan 2010
    18,988
    Re: CYA Level?
    Quote Originally Posted by sfsendlesspool View Post
    Target 3, minimum 2. You might be able to go a couple days between additions. Only testing will tell. Just stay above 2 FC and you won't have any problems.
    Mar 2016
    York,Pa
    18
    Re: CYA Level?
    Interesting. The manufacture recommends between .5 and 1.
    DFW, TX
    24,485
    Re: CYA Level?
    The MFG probably can't even spell CYA and has no idea what it is or what it does.
    Richard320's Avatar
    Jan 2010
    18,988
    Re: CYA Level?
    That would be with no CYA. And that .5 FC with no CYA is probably harsher than 3 with 30 CYA.
    The graph's a little hard to read, but if you're into technical stuff...
