Thread: Intelichlor flashing continously green yellow and red light
    May 2016
    Stevensville, MD
    2
    It is supposed to stop after 2 minutes- ours will not stop flashing- tests show chlorine and free chlorine high and the cell light is off. Why is it continuously flashing- we have a salt pool and I am unfamiliar with this system. Can someone direct me in the right direction to get this fixed and to have the lights stop continuously flashing? What am I missing?
    Thanks so much just found this site!
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Re: Intelichlor flashing continously green yellow and red light
    Welcome to TFP.
    Without knowing your model, I suspect that flashing green indicates low salt. Do you have a test kit with salt test?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    May 2016
    Stevensville, MD
    2
    I bought a regular test kit at Lowes- should I get a special one?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    For ongoing maintenance of your pool, yes you would be well served to have a good test kit. But right now, do you have the ability to check your salt ppm? I'm guessing your SWG is trying to tell you it is low on salt. If it got too low to produce chlorine it would most likely stop flashing green and show a red light indicating it was no longer producing chlorine.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Welcome to TFP!
    What light(s) is flashing?
