Thread: Too much space between liner and wall?
    Jan 2015
    Schenectady/NY
    4
    I mistakenly filled my pool before pulling the winter cover off. When I pulled the cover off I found the liner had pulled away from the coping over a good 18" stretch. I expect I have to drain the pool, pour hot water on the liner, and try to work it back. Boiling hot water by itself doesn't give me nearly enough stretch, so I will have to drain. I'm concerned by the space behind the liner, however. I will have to stretch it about 2 inches and, at the very top, there will be about a half inch between the wall and the liner once I fix it. (See pictures.) That seems like it could pull right out again. Is the polymer wall shifting? Or am I paranoid? (Or both?) Thanks for any advice! IMG_20160530_152624.jpg
    Apr 2013
    Sacramento, CA
    2,769
    Re: Too much space between liner and wall?
    You need to drain your pool down a couple of feet. Wait for a really warm day and move it back into place. The warmer the day and more direct sun the easier it will be. Have 4 or five people on hand to help.
    Can't tell if the walls have shifted from the picture.
    Jan 2015
    Schenectady/NY
    4
    Thanks very much. (I thought I had uploaded two pictures.) The wall is set back from where the liner will insert by about inch. I will wait for a warm day and bring out a pot of warm water with me.
