Thread: My test results are baffling me.
    JenniferJuniper2's Avatar
    Mar 2015
    sacramento, ca
    134
    Okay, so I am new to testing my own water. I have two tests kits, both Taylor brand. One is an OTO kit that tests total chlorine, bromine, and Ph. The other is a K-1001 DPD that tests free chlorine, bromine, and Ph. We tested out water at a pool supply store on Friday and it said our total chlorine was at 10 and the free chlorine was at 10 as well. We tested it with the OTO kit for total chlorine the next day, Saturday, and it was at about 5 ppm. The DPD kit was at about 5ppm as well. We had several people in the pool on Saturday and Sunday. Now it's Monday and the total chlorine reads about 1ppm and the free chlorine is basically completely clear, or zero?! Is this normal? How can a pool go from 10ppm free chlorine on Friday to 0ppm on Monday?
    ETA: we did add a little acid in Friday because the Ph was also really high (8) and we brought it down to 7.2. But the Chlorine levels were still high on Saturday, as mentioned above.
    15k gal freeform sport pool with rock waterfall. Replastered 5/2016 with Tahoe Blue Quartzscapes
    Taylor FAS-DPD K-2006 test kit
    Jacuzzi 2002 J 310
    May 2016
    Lynchburg, VA
    49
    Re: My test results are baffling me.
    I'm still a newbie to the TFP method, but I'd wager a guess that your reading at the pool store was inaccurate, and you were actually at or around 6-7ppm on Friday. Then it would be pretty normal to lose 2ppm per day, especially with a heavy swimmer load. Add chlorine to bring it back to target for your CYA level and I'd keep testing everyday yourself. If you find you're losing more than 3 ppm or so a day, you might need to SLAM the pool because that's one indicator there's something in the water using up the chlorine.
    12250 gallons | IG | Vinyl liner | Sand Filter | Emerson 1081 Pump EUST1102 | Hayward Pro Series High Rate Sand Filter Model #S166T | Pool <10 yrs. old | Taylor K-2006 test kit | SharkVac automatic pool cleaner
    Aug 2014
    Northern IL
    4,615
    Can you get a better FAS-DPD test kit?
    Apr 2016
    College Station, TX
    79
    That actually seems pretty normal to me, especially with use.
    Things to consider:
    1. Pool store tests are historically very inaccurate
    2. OTO and DPD are both only capable of giving you a rough idea of your chlorine levels.
    3. The first step everyone here will recommend is buying a good test kit with the FAS-DPD chlorine test, such as the TF-100 or K-2006C.
    So, with all that said, what are you intending to do? Because the answers may be different depending on your intentions.
    When I first came here, I was really just curious about this TFP method and some of the folks who were very passionate about it turned me off a little on it.
    If you are looking to take total control of your pool, save some money and have beautiful water, you have come to the right place. Folks here are pretty smart about that subject.
    In other words, whether you want to jump in head first or just see how it works, let us know so we know how to respond.
    Intex 16'x32'x54" 17Kgal AGP since 2014. Sand filter, Hayward skimmer, home built 10'x15' deck and stairs, solar heater. High TA tap water, moderate rainfall, weekly use. Treated with 10% bleach, MA and some dichlor initially. Soon to add borates.
    Taylor K2006C
    Future projects - automatic chlorine pump, online pool sensors, better heater, IGP (maybe)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    Agreed, pretty normal. Your pool in perfect condition with nobody swimming in it will use about 2 ppm of chlorine per day and up to 4. Add a bunch of people swimming and that chlorine usage will double or more. It is important to test chlorine before, during and after a big swim day to make sure that the pool is properly sanitized and eliminate risk of person to person disease transmission. To ensure a properly sanitized pool the chlorine level must remain above minimum level for the CYA level on the Chlorine CYA Chart. As soon as it falls below minimum level the pool becomes unsanitary and algae, bacteria and viruses are no longer being killed quickly enough.
