Thread: DE added to Sand Filter. ???
    May 2013
    Tulsa, OK
    83
    I just added 1cup of DE diluted in water to my sand filter. I was expecting a pressure increase but I actually lost 3psi almost immediately. Should i continue to add DE until i reach my 1 psi gain? Or is there another issue going on?
    12x24 Doughboy. 8700 gallons~ 2 HP Dyanmo Pump~ 26" Sand Dollar Filter~TF 100 test kit~ Zodiac Ranger AGP automatic cleaner.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: DE added to Sand Filter. ???
    Wait a few minutes. Could be a clump of DE is clogging the pump impeller. Give it time to dissolve.
    May 2013
    Tulsa, OK
    83
    Okay. My normal clean filter pressure is 9-10psi.
    Added DE 1 hour ago and pressure is staying at 7psi.
    DE was diluted in water completely prior pouring in skimmer.
    I am also getting some bubbles from the return eye now.
    Should I backwash and start again with the DE addition and see how the pressures react?
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    There is no hard fast amount of DE that it takes to raise your psi 1 pound. So if it were me, I'd try another 1/2 cup and see where that takes it. Just add it slowly, or as you did diluted in water added slowly.
    If you want to backwash it out at ant time no harm will have been done.
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by heavyweight_4u View Post
    Low pressure and bubbles sound more like an air leak. Did you, by chance, backwash just before adding DE? Maybe the water level is now too low and you have a vortex in the skimmer. Go take a look. If you see a whirlpool, there's your air bubbles and low pressure. Fixing that is as easy as dropping the hose in.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Ok. If you have a larger problem, I'm sure Richard and other experts can help get you straightened out BUT.........this happened to me this year too. Pressure had seemingly been about 1 pound lower than normal for a long while. I added DE and my pressure dropped. I went nuts thinking I had a blockage. Long story short......my gauge was bad. That drop when I added DE was my first sign.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
