Thread: coping face broke off
    until i get around to replacing the coping can I patch the crack with silicone? or cement patch?
    the pool/coping is at least 7 yrs old. probably 20 yrs, it came with the home
    the broken piece on the bottom came off in one piece
    thanks
    2nd photo is upside down, sorry
    Apr 2013
    Sacramento, CA
    2,769
    Re: coping face broke off
    Because your plaster is looking OK those are probably caused by deck movement. Its hard to tell. I would be using some mortar. Silicone or Other plastic based caulks will be temporary.
    Where are u located?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I would use liquid nails on that, a special formulated for masonry Epoxy.
    Divin Dave,
    tampa, florida
    it's an indwelling pool surrounded by a concrete patio
    movement could be possible. the ground here is very soft/shifting and sink holes are all over the place
    i'm going to try the liquid nails
    thanks!
