Thread: Need to replace power cord: options, please
    Jun 2013
    Boston, MA
    91
    The power cord of my booster pump is starting to fray where it enters the pump. Can I use a generic power cord that has a twist lock prong? If so, can you recommend a brand and model? I see options on the line for over $30 which seems like a lot for just a cord.
    Inground pool; about 20,000 gallons (18' x 36'); pool liner (vinyl?) a few years old; Hayward pump SPX2607X10
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Need to replace power cord: options, please
    Quote Originally Posted by gb99 View Post
    If you have slack enough, you can just undo the cord inside the pump, undo the clamp, and then cut the cord down a few inches and reassemble it.
    If you don't have enough slack, disconnect the wires inside the pump, undo the clamp, and take the cord to the nearest mom-n-pop hardware store and let them get you something that will work. For a twist-lock, thirty bucks seems reasonable. Just a replacement plug is about fifteen bucks.
    All you really need to be sure of is that the plug is the right one and that the wires are at least the same size as the originals. Remember, on wires, the smaller the number, the bigger the wire.
