Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: We don't need no stinking algae HELP!
    Aug 2011
    Ct
    39
    Opened the pool last week and the only thing missing were the gators. Keep in mind this is Connecticut. Shocked the pool three times and now have an improved milky green color. The chorine level is still high and I've attached some photos. Here are the results of the latest tests
    Chlorine Drop Test - 27.5 ppm
    CC - 2 ppm
    CYA - 50
    Any suggestions greatly appreciated.
    1) 21,000 gallons
    2) Hayward cartridge filter with Super Pump
    3) Inground
    4) 16 x 32 vinyl liner
    5) Mineral Springs SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: We don't need no stinking algae HELP!
    The CC says you still have something growing in there.
    The cloudy says you still have some filtering to do.
    The FC is higher than needs be, so more bleach is not the answer.
    Have you checked behind the lights? See Think I may have found my FC demand issue?
    Aside from that, all you can do is try to improve circulation so that whatever particles are in the water find their way to the filter. Brush. Aim a return down to stir up the deep end. Open the main drain is you have one. Set the vacuum down on the bottom upside down to act as a main drain if you don't have one.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    You say you "shocked" the pool three times.....
    Have you followed the instructions on how to SLAM your pool?
    Support the site
    Aug 2011
    Ct
    39
    Thanks. I have fiber optics so I don't think it's the lights. Is there any other chemical I can use?
    Thanks, Tim. I slammed it as per the instructions.
    1) 21,000 gallons
    3) Inground
    Richard320's Avatar
    Jan 2010
    18,967
    Flocs and clarifiers seldom work as promised and almost always gum up the filter. That's why we don't recommend them. Improve circulation today and give the pump a break tonight. Maybe you'll get lucky and the stuff will settle out so you can vacuum it up.
    Aug 2011
    Ct
    39
    Thanks. I have the vacuum sucking up from the deep end now. I'll try your suggestion and give the pump a break tonight and see what happens. I never had this problem before. Could it have been the mild winter?
    1) 21,000 gallons
    3) Inground
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by pixpicker View Post
    Warmer water means faster algae growth. It could be just an awful lot of dead algae.
    Aug 2011
    Ct
    39
    I still need HELP!!! The pool is clearing but only slightly each day. At this rate I may be able to use it in September. I'm not crazy about the Floc technique and looking for a flocking alternative. Any suggestions would be greatly appreciated.
    1) 21,000 gallons
    3) Inground
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Are you keepin your chlorine at shock level for you cya?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Richard320's Avatar
    Jan 2010
    18,967
    Have you been following the SLAMinstructions?
    People have started with a black gooey pool and had it crystal clear in less than two weeks doing it that way. Recovering my old inspirational links
    It it's been consistently above shock level for your CYA for the last couple days, you should have seen some improvement.
    It's your pool, so you can add what you want. I've never used anything like flocs or clarifiers, so I have no recommendations there.
    Central NJ
    44
    How are you exactly getting this reading.. ?
    To test high chlorine levels you need a DPD powder.. See here
    Amazon.com : Taylor Replacement Reagent FAS-DPD Refill Kit (Large) - Over 100 Tests : Patio, Lawn Garden
    With a CYA of 50 ( if that is indeed accurate ) your shock level needs to be at a 20.. Thing is you need to test very often and not let it drop.. Hold it there all day.
    You need to set it at 20 at night and test first thing in the morning.If it drops then you know something is still eating your chlorine.. The filter needs to run on high 24/7.. ( Possibly your filter is compromised also...)
    Is the pressure going up from all the filtering?
    Keeping shock level a bit higher is ok.. Dont have to be right on 20..
    Lets start there..
    Mike
    Sorry just read you have swg....
    To add / edit with a swg you need 60-70 CYA and a shock level of 28 or 30...
    12X18 AG, 6200 gal
    Hayward S166T sand filter, Switched back to 100 sq ft cart.
    Hayward 1hp power flo matrix two speed pump.
    Been using BBB since pool was new in 2004. Never had any problems.
    Aug 2011
    Ct
    39
    Thanks for the suggestions. Will start from scratch tonight and report my findings. I may have to quit my day job just to maintain my pool.
    1) 21,000 gallons
    3) Inground
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    If you test and add
    First thing in the morning
    As soon as you get home from work
    Once more before bed
    that's "enough". Test and add to get to SLAM level each time.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Squeeze a brush in there somewhere.
    Aug 2011
    Ct
    39
    I'm starting to see some improvement although very slowly. Here are the numbers from last night.
    FC = 10ppm
    CC = 1.5ppm
    TA = 140
    CYA = 90
    Any suggestions?
    1) 21,000 gallons
    3) Inground
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    The SLAM level for CYA of 90 is 35 FC. Pool School - Chlorine / CYA Chart You are WAY below that.
    You have to maintain 35 until the slam is over. Test and add at least 3 times a day. And yes, brush at least once.
    e: How did your CYA almost double?
    Aug 2011
    Ct
    39
    Thanks for the reply but I'm getting really discouraged. I have the FC at 35 now and will attempt to keep it there. Pool is still really cloudy. I don't have an answer to the CYA question but it must be user error.
    1) 21,000 gallons
    3) Inground
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Can you tell us how you're testing your water?
    Unless you are using stabilized chlorine, your CYA wouldn't go from 50 to 90. Are you using liquid chlorine?
    Knowing your CYA number with accuracy is imperative to knowing where to target your chlorine for shock level.
    Aug 2011
    Ct
    39
    I'm using a TF-100 test kit. I'm obviously not great at the CYA test because I just tested it (in the rain) and got a CYA of 50. I'm using liquid bleach.
    1) 21,000 gallons
    3) Inground
  20. Back To Top    #20
    DFW, TX
    24,450
    Cya test pics
    https://www.taylortechnologies.com/C...P?ContentID=36
    Extra instructions
    Pool School - CYA
    there are also vids on TFTestkits.net
