Results 1 to 20 of 20
Thread: How much bleach should i buy?
    May 2016
    Hampton
    29
    On my way to buy 10%. I've got a 20000 gallon IG gunite pool. How much do you think I will need for a 3 month season?? First year with a pool, ordering the test kit this week.
    20000 gal in ground gunite
    Hayward s200 sand filter
    Hayward 1.5up single speed pump
    JoyfulNoise's Avatar
    May 2015
    13,207
    Re: How much bleach should i buy?
    Quote Originally Posted by Rurak View Post
    You want to be careful stockpiling bleach because it breaks down over time. You need to know the date codes of manufacturing (typically printed on the bottles or box). You might get 10% initially but, by the end of 3 months, it could have degraded down to 8% or less. Bleach should always be stored in a cool dry place (preferably indoors) as temperature exacerbates the degradation.
    Matt
    May 2016
    Hampton
    29
    So how much do you think is reasonable to buy at one time? I have no idea how much I will need?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    If the pool is green or cloudy, buy all your car will hold.
    If the pool looks okay, figure you'll use about 3 gallons a week. That's 2 ppm/day in 20,000 gallons. So realistically, 10 gallons will keep you going about three weeks. But if it comes in 4 packs, buy 12 jugs. No more than that.
    May 2015
    13,207
    While Richard gave you the answer, you should learn to use Pool Math so that you can do the calculations yourself. Instructions on use are here - Pool School - PoolMath
    Matt
    May 2016
    Hampton
    29
    Pool is Crystal clear. I can't seem to get pool math to work on my phone
    May 2015
    13,207
    It works on my iPhone running the Chrome browser. What are you using?
    Matt
    May 2016
    Hampton
    29
    I just got it working! Thanks guys.
    May 2015
    13,207
    Memorial Day is typically a peak usage weekend for TFP. So you can expect some server delays or weird error messages. I just got one myself.
    If possible, store an offline copy of the PoolMath webpage on a computer or tablet device so that you can use it even if your network goes down.
    Matt
    May 2016
    Hampton
    29
    May 2016
    Hampton
    29
    I'm at the store, they have 12.5% sodium hypochlorite sold as "mega shock" for 2.99 a gallon. Is it a good deal?
    Richard320's Avatar
    Jan 2010
    19,004
    Not a steal, but a very reasonable price.
    May 2016
    Hampton
    29
    I'm on the fence. I've got a bucket of 3" pucks from last year. I hate spending the money when I've already got the stuff at home. I know it raises CYA, I drain about 1/4 every winter and full back up in the spring. You think I can get away with pucks this year?
    Richard320's Avatar
    Jan 2010
    19,004
    That depends entirely on what the starting CYA is. Remember that as CYA climbs, so does the minimum FC level. So you may still end up needing to supplement the FC with bleach. Otherwise you add more FC with an extra puck, which adds more CYA which raises the minimum again, so you add more FC with an extra puck, which adds more CYA which raises the minimum again, so you add more FC with an extra puck, which adds more CYA which raises the minimum again, so you etc etc etc ad infinitum until you're posting in August that the pool is always cloudy or the green won't go away.
    Pucks will last for years if the bucket stays closed. I use pucks to replace lost CYA from backwashing and also to chlorinate when I'm out of town for more than a couple days.
    Besides adding FC and CYA, pucks are also very acidic. If you think you can juggle three parameters, go for it.
    May 2016
    Hampton
    29
    My CYA is 30 on the strip. Ch is 200. Fc is 1 ph is 7.2. Ta is 40
    Richard320's Avatar
    Jan 2010
    19,004
    Test strips?
    I wouldn't add anything but bleach until you get a proper test kit.
    You'd probably be just as accurate with your tests doing it like this
    May 2016
    Hampton
    29
    Hahaha. I'm ordering the taylor kit you guys recommend on here. I feel like I could just dump a bunch of 100s in the pool instead of chemicals!!
    Richard320's Avatar
    Jan 2010
    19,004
    Go the pool store route and you will!
    The test kit is an investment. It will pay for itself two or three times over in the first year alone. Don't believe me? Ask him: another Added shock chlorine but sill, FC = 0 ?
    May 2016
    Hampton
    29
    If I was even close to approaching 700$ in chemicals for the year I would give up for the year .... I'm finishing out my 3" pucks and switching to the tfp method
  20. Back To Top    #20
    Jun 2012
    Butler, PA
    336
    I buy mine 3 cases at a time (12 bottles). It's enough to get you going if you need to spring into action, it's enough to share if the neighbor needs some. And if it isn't going as fast as I like it to go I use it in the bathrooms to clean the toilets and I'll scrub the coolers and outside chairs down.
    Our pool sees a lot of action, we have a ton of trees and a huge planted field way out back so I go through it at a decent rate.
    $2.99 is what I am paying for my 12.5% ~ it's a really good price for that strength in my area. We did just get a Rural King, I don't know if you have one of those near, but I hear everyone saying their prices are great in general and if I am not mistaken I believe I read here on the forum they have bleach priced nicely.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
