Thread: Boric acid poisoning
    May 2016
    Ocala fl
    13
    So, after reading of the advantages of using borates to help stabilize the PH and the aesthetics of the pool, I am considering adding boric acid to the pool this year. But, then I have heard about chronic boric acid poisoning from repeated exposure and ingestion. Now, obviously we will not be using the pool for drinking water, but often times have children in the pool - and as any one with experience with children and swimming pools know - they tend to ingest a lot of water when playing in the pool. At 50ppm, is there any concern with this type of poisoning? I know that with many things "we have always done" can later be identified as the root cause of many ailments.
    Any chemists out there that can eliminate these fears?
    Thanks
    Built 2007, IG 15,00 gal free form, marcite, with spa and synthetic rock waterfall. Hayward 2.5hp single speed, pump and SWG cell. Cartridge filters - Pleatco. Jandy gas heater. Zodiac barracuda vac. Screened enclosure.
    JoyfulNoise's Avatar
    May 2015
    13,187
    Re: Boric acid poisoning
    Matt
