Thread: Need help replacing Coverstar sliders
    What's the best way to replace the sliders on a coverstar cover? I have the type where the track sits under the bullnose. Do they have to slide into the track from the end or can I just hook it on wherever?
    BTW I'm going to try 3D printing replacement sliders rather than spend $50 on two pieces of plastic. If it works out I'll put the design up on thingiverse.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Need help replacing Coverstar sliders
    bump
    Mar 2013
    maryland
    138
    I usually replace the sliders near the motor end of the track with cover open. While they just hook on. a little back and forth may help get them in. I use a right angle phillips to hold the screw that goes from the bottom up.
    Have you had any luck with the 3D ?
    " A little knowledge is a dangerous thing"
    19,000 gallon sylvan pool, Easytouch 2 4p automation, Screenlogic interface, Intelliflo VF 3050 pump, Intellichem with Intellichlor 40 chlorinator/Muriatic acid, Raypac millivolt natural gas heater.Polaris pool cleaner with booster pump.Coverstar automatic cover hydraulic mechanism with PCS cover. Wet edge Luna quartz finish 2016. Northeast climate.
