Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: What caused my wrinkle?
    Sep 2015
    Columbus IN
    52
    Yesterday when I opened the auto cover on our pool I seen a big wrinkle about 18" long below the simmer. It ran from the simmer on the wall towards the bottom of the pool. Sorry I didn't get a pic of it. I was able to work the wrinkle out and can't tell it was even there now. Here are my numbers.
    FC 6.5
    CC 0
    PH 7.6
    TA 80
    CH 350
    CYA 50
    I am having a FC drop of 2.5 to 3.0 a day. Was adding CL to 9 to account for that. Was running variable speed pump 16 hours a day. Not running from 12:00 AM to 8:00 AM. CL PH Testing and adding CL at 8:00 PM. Closing cover after that to keep heat in water. Run heater from 8:00 am to 12:00 pm if needed. I heat the water to 82 degrees.
    I don't think that it was a chemical wrinkle as I was able to get it out of the liner.
    Last night I left the pump run on 1200 rpm all night and no wrinkle today not saying that was what caused it.
    Have used the auto cover closed with heat on before during the last three years.
    We have had no large rain amounts and there was no water behind the liner.
    I really don't know what caused the wrinkle so I would like your opinion.
    15000 gal, IN, Hayward Super Pump VS, Hayward Heat Pro Titanium heat pump model number HP2110T, vinyl, Dolphin Apollo.
    Hayward sand filter model number S210T, TF-100 test kit with speed stir. It was built in 2012.
    Sep 2015
    Columbus IN
    52
    Re: What caused my wrinkle?
    I lowered the chlorine level and seems to help.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Hard to explain if you have no symptoms of a leak, such as water loss, or recent heavy rainfalls with a high water table...
    Isolated Spa - 345 Gallons
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Do you lose water with the pump NOT running? It could be a skimmer leak that leaks only when the pump is off. I can not imagine it has anything to do with FC at 9 and CYA at 50. That should be absolutely no issue at all.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Sep 2015
    Columbus IN
    52
    It has spread to other parts of the pool yesterday. Liner is loose fitting in places now.
    Sep 2015
    Columbus IN
    52
    I did a retest of the CYA level this morning as the sun is out very bright today and I get a reading of 40. Yhis is very strange. Open to any ideas.
    Sep 2015
    Columbus IN
    52
    Did a retest of CYA this morning as it is sunny and got a reading of 40. This is very strange. Open to any ideas.
    Feb 2014
    Central Minnesota
    5,080
    Do you have any symptoms of a leak, such as water loss or having to refill more often than usual?
    Sep 2015
    Columbus IN
    52
    I had a different bottle of the R-0013 CYA reagent and retested with it ruling out anything wrong the reagent I was using and it was 40. My FC is at 3 and the liner is looking better?????? Any ideas are welcome.
    No leaks. I topped it off on Saturday and still at that level.
    Pool Tool's Avatar
    May 2014
    757
    Razor - you obviously don't have an autofill do you? I just have to ask. My vinyl pool has stayed at elevated FC for weeks before and I never had the liner shift or fade or anything. I just cannot imagine this is a chemical issue, but have no good idea otherwise. I have only seen liners shift or bulge do to hydrostatic pressure pushing the liner out from behind.
    Sep 2015
    Columbus IN
    52
    No auto fill . Yesterday I could put my hand on liner in place by simmer and move it easily. To day it is solid with no wrinkle. Yesterday I seen wrinkles forming around the light. Today they are going away. I looks like a chemical issue now but I don't understand why it is. Thinking of raising CYA to 50 and treat it as it is 30. I can't run out of FC.
    Pool Tool's Avatar
    May 2014
    757
    Hopefully a few more folks will weigh in. That FC concentration is quite low already and even if it was high - it seems odd that it would be localized stretching of the liner. There has to be something behind it to push against the weight of the water on the inside of the pool and bubble it out. If liner was just stretching, I think it would do more sagging down then bulging out. I am definitely not saying you are wrong, just perplexing as many, many members manage levels in line with your's without liner issues. Definitely and worrying scenario.
    Do you have landscape irrigation lines close? Some other source of water independent of the pool nearby?
    Sep 2015
    Columbus IN
    52
    Sep 2015
    Columbus IN
    52
    Yesterday I found it in several places in the pool. It started below the simmer of that was the only one I noticed at that time. The wrinkles were like pluckering with no water behind them. To it is getting better but I have not added Chlorine in 24 hours.
    Feb 2014
    Central Minnesota
    5,080
    That it's going away the same time as you're allowing FC levels to fall is more likely coincidence than correlation. That change in FC level is fairly insignificant when it comes to the aggressiveness or overall chemistry of the pool water.
    Sep 2015
    Columbus IN
    52
    I added chlorine yesterday when it was looking better. Added to FC 7 and within three hours I was having problems again. I havent added since then and it looks good. If it is not the chlorine I have no idea what it could be.
    Sep 2015
    Columbus IN
    52
    I only had my VS pump for a couple of weeks. When I was adding chlorine I was running it on high for 30 minutes. Should that time be longer?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,774
    This is olny a wild-arsed guess here.
    Low Ph from a covered crash is normally the first suspect in liner vinyl expansion/wrinkles, and high ph is the second suspect in terms of liner aging behavior.
    But maybe with only a half hour, low speed circ combined with autocover and heat, you're getting unevenly distributed ph?
    Why not dose in the morning, once the cover is open, leaving it lower at night when the cover is closed and see if that improves liner behavior?
    You didn't crash TA/ph wise over the winter, did you? That can change the composition of the vinyl so that its heavy and stretches.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Pool Tool's Avatar
    May 2014
    757
    Razor - So you see a correlation between chlorine additions and the liner bulges right? Do you always run the pump at high when you add chlorine? Your chlorine will still mix at low speed, albeit just a little slower. Leave your pump on low when you add today so you can rule out that out as a contributor and let us know.
    Thanks, good luck.
  20. Back To Top    #20
    Sep 2015
    Columbus IN
    52
    My PH and TA were both high when I opened the pool. Will try your suggestions. Even the wrinkles around the light are going away now. The month of April I was slamming the pool without any problems. I didn't start getting any problems this year until I started the heat pump and closing the cover at night last week.
