Thread: Super low FC and CYA
    May 2016
    Ona WV
    2
    I'm new to the forum. I cannot get the FC or the CYA to raise to ideal level. All other levels are perfect. What do I need to add?
    Karen Holley
    20x40 in ground pool
    vinyl liner
    sand filter
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,075
    Re: Super low FC and CYA
    Welcome to TFP!
    Could you post a full set of test numbers and the test kit you are using?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2014
    15,166
    Hello Karen and welcome! Also please add which test kit you have to your signature when you get a moment. It keeps us from asking each time.
    May 2016
    Ona WV
    2
    I'm using Aqua Check
    FC is 0
    CYA is 0
    Karen Holley
    vinyl liner
    sand filter
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,075
    Unfortunately that is not one of the recommended kits. I do have a link in my signature to TFTestKits, or a Taylor K-2006 will do as well.
    When you get your kit post a full set of numbers and we will go from there.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    Based on the info you have provided so far the most likely scenario is that you have algae growing in your pool consuming your chlorine as fast as you are adding it, and the sun is also consuming it rapidly. To clear algae from your pool we use this process, Pool School - SLAM - Shock Level And Maintain. To perform a SLAM you need an FAS/DPD chlorine test. The best way to get that is to order a TF100 with XL option from TFTestkits.net. I have been buying my test kits there for years.
    While you wait for the kit add a gallon of bleach to the pool daily and brush. And read this, Pool School - ABCs of Pool Water Chemistry and this, Pool School - Getting Started
