Thread: double check my work please
    May 2016
    West Mifflin PA
    4
    I started SLAM last week but ran out of reagents. Started back up Friday and I am on fourth day and seem to be at a stand still. I started with very green pool, with lots of leaves and debris in the bottom. I have been checking FC 2-4 times per day, and vacumming/brushing 2 times per day.
    PH 7.2
    CYA 50
    TA 100
    CC 0.5 yesterday, this morning barley turned pink so i am guessing less than 0.5.
    FC ranging from 17-20, ( started shooting for new target today of 24 incase my CYA reading was off, but I got 50 friday and 50 today.)
    I have lost 4-5 FC overnight last two nights.
    My guess is I just need to keep running filter, I have been running it 24/7 and cleaning cartridge anytime I notice water flow slowing down, 4-5 a day. image1.jpg
    Do you guys see anything else I can be doing.
    17000 gallon semi inground pool, hayward super pump VS, Hayward 175 ft cartridge filter, 24 ft of head.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: double check my work please
    Keep brushing
    And brushing some more. Keep chlorine at target as often as possible. Don't bother with PH test as it will not be correct at such high CL levels........sounds like you've got this.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    First of all you should rotate that pool 90 degrees so the water doesn't fall out!
    Looks like you are going a good job, OCLT shows there is still more work for the chlorine to do.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2014
    15,221
    Definitely stay at it. If your CYA was 50, then your SLAM FC is 20 so keep it there. It you tested your CYA on a cloudy day, the black dot may have disappeared early which means your CYA might be slightly higher. In any case, patience & maintaining are key. Following all the instructions on the SLAM page (link below) are critical to your success as well. Hang in there, you'll get it.
    May 2016
    West Mifflin PA
    4
    Thanks, that is what I was thinking. HAHA, i hurried up and uploaded photo,didnt realize it was sideways.
