Results 1 to 8 of 8
Thread: Hard piping new Installation
    May 2015
    fairfield, nj
    19
    Hello all,
    I'm installing a 15x30 above ground pool and need help/instruction on hard piping. I will be using a hayward cartridge filter, hayward pump and chlorinator. The pump set up will be 10 feet away from the pool, hard wired at the house to a timer. I don't plan on removing equipment, just winterizing by removing water from the system with my shop vac. What would be the correct diagram of piping this combination to the pool? Hers a pic of the equipment and location:
    Thanks
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Hard piping new Installation
    skimmer>suction side>filter>return
    I did 2 suction side and 2 returns using Jandy 3 way valves, I have close to the same setup (SWG extra) I also added a 3 way to use as a backwash or to lower water
    Before paint
    May 2015
    fairfield, nj
    19
    so you have two skimmers and two returns on your above ground pool? do i need valves also? I'm not sure how these systems operate or are cleaned/maintained. Thanks
    Jul 2013
    Fletcher, OK
    3,353
    I have 1 skimmer and 1 suction port for my cleaner and 2 returns
    the 2 on the left are the returns and the one with the hose is connected to "the poolcleaner"
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    This is how I originally had my equipment pad set up. I have ball valve unions on the suction and return lines so I can shut off water flow when needed, and a union between the pump and filter to make maintainence easier. I switched to a sand filter a couple of years after these pictures were taken, but the set up is the same.
    Quote Originally Posted by zea3 View Post
    Love TFP? Become a
    TFP Supporter!
    May 2016
    Clark, NJ
    6
    Cowboycasey, is that 1.5" or 2" hard pipe? my skimmer, return, and pump are 1.5" and my filter and SWG are 2". I'm trying to figure out if I should do 1.5" pipe all the way thru or: from skimmer go to 2", reduce to 1.5 into pump, increase back to 2" into filter all the way up to return which I have to reduce back to 1.5"
    thanks
    Zea, how's the flex pipe working for you? was it easier to work with? is it 1.5"?
    thanks
    Jul 2013
    Fletcher, OK
    3,353
    I did all 2 inch pipe and used the 1.5 inch reduce Hi temp unions for skimmer, thru wall, and pump connections... made it easy
    Praher UNION, 1-1/2 SLIP, HIGH TEMP (215-906) - INYOPools.com
    May 2016
    Clark, NJ
    6
    looks great. I have the same steps. did you fill them with sand or is that a weight attached to it?
