Results 1 to 7 of 7
Thread: Hayward Motor Casing Temperature
    May 2016
    woodland washington
    9
    My 1-hp Hayward pump is in a small room off the deck. The ambient temp in the room was 78 degrees today. Pump runs fine, maybe a little noise on start up but other than that, no issues. Ever sense i bought this residence i notice the motor seems to put out a lot of heat. So today i put my infrared gun on the motor and got these readings
    1) Back electrical cover area - 157 f
    2) Middle of motor casing - 184 f
    3) Motor and Pump connection - 91 f
    Question - what would/should be a ball park normal range.
    Thanks
    18x36 Rectangle, estimated 27,000 gal, new vinyl 2015. Pool was built in 1994
    Hayward Pro Series High Rate Sand Filter, Model No. S-244T, 62 GPM Filtration and Backwash Design Flow
    Hayward Max-Flo Pump ( 1-hp ) 115/230 SP 2807X10
    38,371
    Re: Hayward Motor Casing Temperature
    That seems a bit warm to me. I think you should be able to leave your hand on the motor
    Assuming you are measuring surface temperature, in the shade, at air temperatures less than
    90 F, I would give this as a rough guide:
    Below 135 F, good
    135 to 150 F, warm
    Over 150 F, too hot.
    Support the site
    May 2016
    woodland washington
    9
    Thanks for the responses. Something internal going on that is not good. Started looking online at pumps for replacement and upgrade. Current system is supposed to be original installation, (1994)
    38,371
    Likely bearings going bad. I would recommended upgrading to a 2 speed motor to put in your existing pump. Or consider a full pump replacement.
    Feb 2008
    Milford, CT
    333
    Quote Originally Posted by Crankbait View Post
    Not sure if you've tried this already, but make sure all of the vents in the motor/pump casing are clear.
    My Northstar was running really hot last season, turns out there were vents in the motor case partially hidden by the pump casing. Pulled off the pump casing part that was in the way, cleared out the vents and the motor ran much cooler for the rest of the season.
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
    Is it a 22 year old pump?
    Can you post a picture of the motor label?
    Support the site
