Results 1 to 9 of 9
Thread: Bag or cartridge filter for robot cleaners
    Dec 2015
    Newington, Connecticut
    113
    I'm leaning towards a dolphin robot. Most that I've looked at have a bag with the option for a cartridge filter. Seams like the bag might filter more fine debris. Are the bags that bad to clean vs the cartridge, seams to be the main complaint that I can find.
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Bag or cartridge filter for robot cleaners
    the bag is used for the big stuff like leaves and then the filters get the finer debris
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    The bag works well but it's difficult to clean out and takes considerably more time.
    Pop out the cartridge, spray with water hose and your're done.
    Also, the cartridges come in 2 versions. The spring cleanup one which is sort of file a fine mesh, and the fine particle one. The fine particle one will filter just as fine or finer than the bag will.
    Divin Dave,
    Feb 2015
    Davis, CA
    97
    Or get the Dolphin S300i which has a combination of a "mesh" filter and a fine filter. Dolphin S-series - cleaning the filter - YouTube
    Pool Remodeled June 2015. 18K Gallon IG kidney shaped. Pebble Tec (Tahoe Blue) finish. Jandy ePump 2HP. Hayward SwimClear C2025 filter. Hayward SWG. Jandy iAqualink RS6 automation. 6 Deck Jets. Pool Remodel Link Future: Acid automation. Chlorine automation for winter. Solar panels.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,494
    Andrew,
    I have a couple of old Dolphins which have the heavy canvas-like bags, which can pick up everything... leaves, little pebbles, and dust. I did not find it hard to clean the bags at all, takes five minutes, but you will get wet.
    I now have a year-old Dolphin Premier, which gives me three options....
    1. A thin, cheap-feeling, bag which can be used for leaves and big stuff, but leaves all the dust or dirt behind... OR... 2. A fine screen mesh, which picks up small pebbles, but not much big stuff or any dust or dirt... OR... 3. A pleated flat cartridge filter that picks up sand, dust, and dirt great, but also captures small pebbles in-between the pleats. I find cleaning them to be a PIA...
    My next robot will be the S300 that diverminh is recommending. I like the fact that it uses a "bucket" that can capture leaves and large stuff, a mesh "pre-filter" to capture pebbles, sand etc, and a fine filter to capture dirt and dust, all at the same time.
    May 2016
    Huntsville Alabama
    16
    Quote Originally Posted by diverminh View Post
    Do you run with a combination of your filter screens in? Currently I'm running all 4 sides with the fine mesh and seems to get a lot. I have the "finer" pleated inserts in the bag but just don't know when to use them.
    Jun 2015
    Orange County, CA
    144
    Quote Originally Posted by Tcraw487 View Post
    The s300i basket has integrated filters. You don't need to change them out. It's quite the convenient system. I love it. Super easy to clean and no changing of filters ever for fine or big filtration.
    17k IG plaster pool+ spa, Stonescape mini-pebble midnight blue, marble coping, Trex and porcelain tile decking, Pentair Intelliflo VSP x 3 (filter, laminars and spa jets), Pentair IC40, Pentair MasterTemp 400, Pentair Quad DE 100, Pentair CC 150 for laminars, Intellibrite 5G LEDs, MagicStream Laminars x 3, Intellitouch i9+3 automation with Screenlogic2, IntellipH, Dolphin s300i, TFTest kit, SpeedStir
    Feb 2015
    Davis, CA
    97
    I am running it with the pleated filter as well as the mesh screen. It works for me, so I don't see a reason to change it.
    Jul 2014
    Bedford, TX
    7,494
    Quote Originally Posted by Divin Dave View Post
    Dave,
    OK... I was wrong and your were right!!
    You have said a couple of times how easy it was to clean the Dolphin pleated filters, and I have been complaining about how hard it was for me to clean them. My problem was I was trying not to get wet and cleaning them under a Kitchen-like faucet with a sprayer. I was also a little worried about how robust the filters were and was afraid to use much more than "sink" pressure. So the last couple of days I took your advice and sprayed them with a garden hose nozzle and you were right. It does a great job cleaning them and the filters are way more robust than I had originally thought.. But, at least the way I do it, you get about as wet as you do cleaning the bag style of filter.
    Thanks for the heads-up...
