Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Help! - Itchy skin with red spots after swimming...
    Jul 2015
    Monroe, NC
    15
    Hey guys,
    I am a newbie and have converted over to the TFP method after using the Frog system for several years. I switched over at the end of last season and the pool has never looked cleaner. I do have a question and was hoping someone could give me some advice. My kids will get out of the pool and complain about itching with dry skin and occasionally have red splotches on their backs\abs. Has anyone ever had this issue before? Just trying to find out if I am doing something wrong. Thoughts? Suggestions?
    My pool is 17200 gallons
    FC = 7
    PH =7.6
    TA = 80
    CYA =45
    CH = 260
    Borates =50
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Re: Help! - Itchy skin with red spots after swimming...
    Hands, Foot and Mouth Virus? Have your tried lowering the FC level to the minimum to see if that helps..
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    What's the CC reading? CC is the stuff that really irritates skin and smells like a water park. And is the pool fiberglass, by chance?
    Jul 2015
    Monroe, NC
    15
    After they get out of the pool and take a shower it seems to help. The pool is vinyl. I will have to check the CC level. What is the recommended level and how do you adjust?
    17280 Gallons Inground Vinyl Pool
    AquaTools AT3123 Sand Filter
    Pentair SuperFlo Hi Performance 1HP Pump
    Installed 2011
    Dolphin Deluxe 4 Automatic Cleaner
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I have seen what your talking about but it was with Bromine in my hot tub, most people that I have heard of this also have hot tubs...
    Your numbers look good... what is the CC at, that will tell us if anything is in the pool using the FC
    I found this from a previous post APSP Newsletter for Public Health Officials, from skimming it, how long have they been in the pool for how many days.. they may have just had too much time in the pool
    could it be heat related?
    Do they all have it or just some of the kids?
    I hope this helps
    Richard320's Avatar
    Jan 2010
    18,995
    Quote Originally Posted by rprice6 View Post
    Okay, vinyl pool rules out fiberglass itch. Recommended CC level is none. Tolerable is .5 or less. You eliminate it by burning it off with lots of FC and sunlight.
    Do you have a FAS-DPD Chlorine test? That's the powder and drops one. That will test FC and CC very accurately.
    Jul 2015
    Monroe, NC
    15
    My kids were in the pool for about 1-2hrs. Not all of them had the problem. Only two of them complained about it and I could see the spots on their skin...
    I just ran out and checked the levels again. My FC is actually 7 and my CC is between 0 and .5.
    Installed 2011
    30,419
    In addition to your CC's, what does your water look like?
    Jul 2015
    Monroe, NC
    15
    It looks crystal clear!
    Installed 2011
    Jul 2015
    Monroe, NC
    15
    I read on another similar topic where it was suggested to either add mortons solar salt or use a chlorine free shock. Thoughts? Thanks again for all the suggestions! I appreciate the help!
    Installed 2011
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Do not use chlorine-free shock. That will mess up your testing for CCs.
    Are the kids using any sunscreen that may not agree with them? Do they sit in wet bathing suits for extended amounts of time after getting out of the water?
    How are you chlorinating your pool now?
    Jul 2015
    Monroe, NC
    15
    I am using bleach
    Installed 2011
    Jul 2015
    Monroe, NC
    15
    Correction - I did use some 10% liquid chlorine that Walmart had on sale along with 8% bleach. Do you think that could be causing an issue?
    Installed 2011
    Jul 2013
    Fletcher, OK
    3,353
    they are both exactly the same, the 10% is just stronger and you use less.. (and usually cheaper)
    I can tell you I have skin problems, psoriasis exactly and the salt helps me very much..
    What test kit are you using, TF100, K-2006?
    Jul 2015
    Monroe, NC
    15
    I have the TF 100. Do you put the Mortons Solar Salt in even though it isn't a salt water pool? How much do you put in?
    Installed 2011
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    Your chlorine is too high for 45 CYA. Refer to the CYA/chlorine chart in Pool School.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    Jul 2015
    Monroe, NC
    15
    Ok I was using the recommended levels listed in pool math (between 4-8). Should I ignore those and try to stay between the 3-6 range?
    Installed 2011
    Jul 2015
    Monroe, NC
    15
    Would the higher chlorine level cause these issues?
    Installed 2011
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    It could with children and people who are sensitive to chlorine.
  20. Back To Top    #20
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Someone mentioned above about sunscreen. One of my children did show a sensitivity to certain sunscreens with red spotty skin. Low PH will cause irritated skin but according to your numbers above that isn't the case.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
