Results 1 to 12 of 12
Thread: Getting the pool going
    May 2015
    Winfield Alabama
    31
    Hey guys I am new to the pool deal, but I just replaced the sand and bought a new filter and ordered the Taylor Tf-100 test kit. We poured algaecide in last night and the pool has turned a cloudy blue instead of green. While I am waiting on my test kit to arrive, and I have significantly reduced the algae what can I pour into my pool?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Getting the pool going
    Hey there,
    Could you please fill out your signature, it will help us give recommendations like this... Trouble Free Pool
    stock up on bleach or liquid chlorine from walmart
    May 2015
    Winfield Alabama
    31
    Done.
    Pool: above ground, vinyl, 24x24x4.5 Hayward pro series sand filter, Hayward power-flo LX pump 1.5HP
    May 2015
    Winfield Alabama
    31
    Can someone help?
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Please don't pour anything into your pool except liquid chlorine, aka "bleach". Algaecides don't get rid of algae, they are meant to prevent it.
    While waiting for your TF-100 to arrive, please only add 1/2 bottle of plain, unscented bleach from the laundry aisle (8.25%) each night until you can bring us test results.
    Make sure you've removed any debris (leaves, dead possums, lumpy stuff, y'know?) from the pool too.
    You're on the right track with ordering a test kit. And even cloudy blue is better than cloudy green, right?
    Jul 2013
    Fletcher, OK
    3,353
    Good Morning
    your at about 13000 gallons, 24 foot round at 4 feet deep.. yep, just use 1/2 gallon bleach a day and use that brush and leaf rake
    once you receive your kit, come back and post your numbers and we will go from there
    I hope this helps
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Read up in Pool School while you are waiting. Here are a few good places to start.
    Pool School - SLAM - Shock Level And Maintain
    Pool School - Getting Started
    May 2015
    Winfield Alabama
    31
    Pour the bleach in front of the jet?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,871
    Yes. To disperse it into the water as much as possible. Then brush around a good bit. Brushing never hurts the pool.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    DFW, TX
    24,514
    Here is a handy page on pool chemicals, what they are, what they do and how to add them to your pool. Pool School - Recommended Pool Chemicals
    May 2015
    Winfield Alabama
    31
    Here are my test results
    Fc=7.5
    Ph-7.4
    Cya-60
    Ch-175
    Ta-120
    And now I have this collecting on bottom of pool when I get close to it vacuuming, it disappears for a bit and reappears image.jpg
    DFW, TX
    24,514
    Looks like dead algae. You have to sneak up on it.
    Numbers look good. Are you SLAMing? Have you done an overnight chlorine loss test? Pool School - Perform the Overnight FC Loss Test (OCLT)
