Thread: Polaris 280 stops periodically
    May 2016
    Fort Worth/Tx
    1
    Hello,
    We just recently had a pool installed. And we just placed the Polaris 280 pool cleaner into operation. The cleaner works for a good bit than just stops for a minute or so then starts moving again. Has anyone had this problem? Or can suggest a fix for this?
    Thank You
    Apr 2013
    Sacramento, CA
    2,769
    Re: Polaris 280 stops periodically
    It should stop every five minutes and back up or otherwise change direction. That's how its designed so it doesn't get stuck. Is that what you are observing?
