Thread: A little cloudy under water ?
    May 2012
    North of Charlotte, NC
    312
    Just started noticing my water is a little cloudy (noticeable when swimming underwater), especially after a pool party of more then 15 at the house yesterday and kids in it ALL day, at least 6-10 kids in swimming at ALL times....My first thought is raise my CYA level a bit along with my FC but now after reading a few posts I may need to SLAM it ?? Water looks clear from looking at it from above but when swimming under water it not as clear as last season, may try the DE in the sand filter as well, never did this method before? Any thoughts on my recent test results ?
    PH- 7.8
    CYA- 35-40
    FC- 3-4 (on the low side)
    TA-130 (a little higher then normal, usually runs 70-80)
    CA- 40 (quite a bit lower then normal, have softened water as make-up now)
    Pump run time is twice daily for 6-7 hrs with a few hours break in between and off overnight, chlorine injection metered each time the pool pump initially starts on its cycle. Injects for 40-50 minutes at full stroke of Stenner peristaltic pump.
    Thanks in advance for any recommendations....
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: A little cloudy under water ?
    You don't list your CCs..... I'm sure you need to raise the FC of the pool to clear the pool after that party you had.
    CYA has nothing to do with clearing your water up. It just acts to hold the chlorine.
    You can perform an OCLT (OverNight Chlorine Loss Test) to see how you're doing, but you might also consider just raising the FC up to SLAM level and seeing if that clears things up from the party.
    Otherwise you dont need to worry about CH in a vinyl pool. You can drop your pH a tad with MA and that will also help lower the TA.
    May 2012
    312
    Quote Originally Posted by YippeeSkippy View Post
    CC's were .5 as usual, I was referring to just raising the CYA up to 50 like I usually run it as well as increase the FC level a tad, may just bump it to SLAM level overnight like you mentioned and check it out in the morning.Yep, just got back from the store with MA and 10% Bleach to dose it up
    Thanks Skippy
    May 2012
    312
    Well passed the over night test , with levels at shock level is it ok for swimmers today ??
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by roadking00 View Post
    Yes. It won't stay that high for long once people start bringing dirt and sunscreen and sweat and snot into the water.
    You can brush and vacuum for days before a big gathering and raise the FC in advance, and the pool with still look awful at the end of the day. It even happens to us experts.
