Thread: Low flow in the pump
    May 2016
    Kaufman Tx
    2
    The water flow in my inground pools pump is low. The vacuum won't work and I can't figure it out. We run the pool year round and replaced the pump last year. I've flushed the skimmer line cleaned all baskets and filters but the pump is still only about half full and just won't cooperate. Switched to main drain with no changes. Any help would be appreciated before I jump into a pool that I can't clean.
    30,432
    Re: Low flow in the pump
    Welcome to the forum. What is the current psi when your pump is running? What psi are you accustomed to seeing?
    May 2016
    Kaufman Tx
    2
    I forgot to mention the gauge is broken
