Thread: Need some help..newbie
    May 2016
    Ontario
    2
    Hi....I'm really really new to this.
    I'm trying to help someone out...this is not my pool.
    They have a Intex easy setup pool witch is filling up right now. I have set up all of the stuff they have, and have some questions...this is not a new pool....they bought it used, hardly any instructions. I need to help them out.
    I have installed the small filter pump that came with the pool, and the Intex Krystal clear saltwater system...I'm sure I have it right.
    So the Intex Krystal clear will run on its own built in timer from 1 -12 hours, but what about the filter pump on a separate plug? I know I can put the filter pump on a timer to run say 6 hours a day.....but how would you run both simultaneously?
    If I put the Intex Krystal clear saltwater system on a separate timer also it would kill the power to the unit and have to be reset all the time.
    I thought I read, that the Intex Krystal clear saltwater system needs to be run the same time as the filter pump? is that right?
    Any help would be great, so I can get this right for the kids.
    Thanks
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Need some help..newbie
    Hi, welcome to TFP! The pump can run on its own but the saltwater system (swg) must have the pump running to function. It will shut off it if there is no water flow through the unit. The timer on the swg should only cut off power to itself and not affect the pump. As long as you have enough outlets to plug in both units you should be able to coordinate running the swg when the pump is on.
    Love TFP? Become a
    TFP Supporter!
    May 2016
    Ontario
    2
    Thanks....for the quick reply
    So the SWG dose not have an internal clock and I can set it to run from 1 to 12 hours.
    Lets say I turn on the SWG at 9pm and set it to run for 2 hours...that means every night at 9pm to 11pm the swg will run on its schedule? I will then set up a separate stand alone timer for the filter pump to run at the same time or even longer?
    Thanks
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Yes, a little longer is better to be safe.
