Results 1 to 7 of 7
Thread: Should i be worried about electrocution?
    When we bought our house, the previous owner had to get the pool back in working order as part of the purchase. I assume there was a light in the wall directly below the diving board, because now the liner is sucked into a perfectly round depression in that spot. Is there any way we can be shocked? How would I know if the electricity was properly removed from this area?
    20000 gal inground vinyl liner, HTH 6 Way test with Taylor FAS-DPD for CL, Dolphin DX4 Cleaner
    Re: Should i be worried about electrocution?
    Find the junction box to make sure that no wires go in the conduit to the light.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Somewhere near the missing light, usually hidden in a planter, or near the equipment pad you ought to see something like this
    Pull the cover off. One side will have wires from a switch, the other should have nothing (except maybe a pull-rope if someone was kind) coming out of the conduit.
    Don't have anything like that. The only thing electrical around the pool is the box my pump timer sits in.
    If there was a light, there's a junction box somewhere. Sometimes it's in the diving board base under the diving board.
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    If you are certain there isnt a J box, then the builder may have installed the conduit from the light housing all the way to the lgiht switch. Somewhere there should be a switch to turn the light on and off. Or perhaps a timer. If you can identify it, you can measure to see if there is any voltage.
    My pool light doen't have a J Box. They ran conduit all the way from teh light to the light switch at the pad.
    Divin Dave,
    No switches anywhere. There is an Eaton pullout switch directly beside my pump timer which I assume cuts the power to the pump. That's the only thing I have outside in the backyard, assuming there isn't a box beneath the diving board. Will have to check tomorrow.
