Thread: Solar cover
    Jun 2015
    Melrose NM
    12
    Solar cover
    Hi, got our above ground pool last year and we had a used solar cover from a friend. It bit the dust so I am needing another one. My pool is 26' and from what I have seen there isn't a 26' cover made. Would it be best to get the 28' and trim or would the 24' that is quite a bit cheaper do the same? Thanks!
    JoyfulNoise's Avatar
    May 2015
    13,230
    Re: Solar cover
    Well, I have a free-form pool so whenever I get a cover I have to trim it. Just know that trimming the cover typically voids the warranty, not that those are worth the paper they're printed on.
    If fund$ allow it, I would go bigger and trim. Exposed edges are more likely to pick up the wind and get blown around.
    Matt
    Jun 2015
    Melrose NM
    12
    Re: Solar cover
    Thank you so much. That's what we thought but just wanted another opinion.
