Results 1 to 8 of 8
Thread: Best "DIY" "Solar Rings"
    Aug 2015
    Folsom Prison, CA
    124
    Lot's of " " in the title, because these are not quite DIY and not quite solar rings, but I finally found the solution to my cover and solar ring issues and it is working great! Basically I bought 10 foot Intex above ground pool covers and used them as solar rings. I even easily cut one down the middle to ensure max coverage. These are only about $12 on Amazon, so I got 450 sqft of coverage for around $60. Similar coverage of the inflatable covers would have been over $700. The video shows my easy way of getting them out of the pool. Using these + solar has allowed me to get 87 90 degrees in May!
    Jeff || 19,000g IGP || SwimClear 3025 Cartridge Filter || Hayward TriStar 1.39 THP pump || K-2006 Test Kit || 80% Surface Coverage Heliocol || Hayward Controller || Hayward Phoenix 4X4 || "Solar Rings" || PoolSkim
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Best "DIY" "Solar Rings"
    That looks like it is working great
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,537
    NICE job! Hummmmmmm wonder if we could keep the cats from trying to walk on them? Will have to play with it.
    Kim
    Aug 2015
    Folsom Prison, CA
    124
    Quote Originally Posted by cowboycasey View Post
    It is working really well. Allows me to hold 80+ over night. Air temp was 85 today so I hit 90 degree water with the solar running due to a starting the day with an already warm pool utilizing the covers.
    Quote Originally Posted by kimkats View Post
    Well they are very thin, so they well learn quick! But realistically if you over lap them a little bit they seem to stay in place pretty well, so you can probably keep a decent sized channel around the edge of the pool to keep them from getting tempted. Only issue there is, is the overlapped section tends to get picked up in the wind, but so far we have had a decently gusty day and they stayed pretty well put on the water. They have a couple holes on the top which I believe helps with anchoring.
    May 2013
    Hudsonville, Michigan
    13
    This looks like a great idea! May be trying this.
    Swimming in Grand Rapids Michigan since 2005
    Doughboy 24 ft round AG, 17 k gallons
    DE filter
    White River 1 HP JH pump
    How much would you say the solar is responsible for the heating as opposed to the rings themselves?
    Aug 2015
    Folsom Prison, CA
    124
    Quote Originally Posted by cnshough View Post
    Well, a lot. I am not really relying on the rings as a source of heat, but more as heat loss prevention which I think they are doing a great job at. I might be getting a couple of degrees out of them, and I had 92 degree water and we swam tonight at 7 pm. It was too warm, but I just got the solar and am pushing it. However, I do not believe I would have gotten there uncovered and this is a quick and easily solution for me for covering. I am totally happy with it so far.
    Aug 2015
    Folsom Prison, CA
    124
    So I just checked and my solar is set to turn itself off at 90 degrees. My pool water is 91 now, so I would have to assume that the extra degree came from the covers since air temp isn't even 90. So looks like they are offering some radiant value.
