Results 1 to 8 of 8
Thread: got mess, want oasis, help me get there?!
    Hi all a picture is worth a thousand words, so the saying goes...
    it ain't purty...
    [attachment=0:ftanatn6]P5100004.JPG[/attachment:ftanatn6]
    One thing that drives us bonkers is the grass. Mow it and of course grass clippings and dust find their way into the water. I am not up to mowing it every other day with an unmotorized reel mower and bag.
    The pool is about 25' from that extension on the left and 50' from the back of the main house. The ground immediately around the pool is elevated from the ground height of the house and surrounding yard by about a foot, foot & a half. It looks rather like they dug it part way in and brought the ground up to it. The pump is at average ground height consistent with the house.
    What we would like is to have this whole area so that nothing outside of pots or built up planters grows. The area is just too big to just pour over and astro turf (financially anyway).
    Pavers more costly yet. Oil dirt for a base?
    The biggest problem is area to be covered and related cost to do so.
    I'm open to suggestions here...
    East Texas Piney Woods
    (more specifically N/E Texas)
    pool data:
    In ground vinyl lined
    23,500
    sand filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: got mess, want oasis, help me get there?!
    Flagstones with polymeric sand or pea gravel between the stones. Depends on if any kind of flagstone is found locally since that affects price. The elevation change is going to want a small retaining wall to step it down so whatever ground cover you choose won't roll down the hill and pile up at the bottom.
    Feb 2009
    West Virginia
    216
    The first thing I suggest is to build some kind of entertaining area from the sliding double doors to the pool. That would cut down on a lot of grass area to start off, as well as providing a way to get from the house to the pool without going through the "yard" and giving you a place for patio furniture down the road. Looks like it is pretty level ground already. You could go with a concrete slab, wooden decking, or other material. Check out the DIY network website and you might find some costcutting ideas. Then you could kill the grass in a peremeter around the pool, perhaps to edge of the bank on the right side of the picture and put down landscape fabric around the 3 remaining sides. You can use landscape rock on top of the fabric, and put your plants where you like. You dont have to do all the rock at once, we put ours on kinda thin at first and then added more bags as we could get them over the season. But at least the grass will be gone! I have found that landscaping around a pool requires a lot of POP too! Good luck and remember, we like pictures!
    WV Girl
    Custom "L" shape IG gunite pool, 36K gal., main drain, 2 skimmers, 3 returns, hayward heat pump, hayward 1.5hp pump with booster pump, ozonator, 4 cartridge filter.
    one dear hubby, two waterlogged kids, and lots of good times!
    Rocklin, Ca
    467
    I think decorative rock like is commonly seen around homes in AZ or NV would fit your requirements. If you're not opposed to using chemical herbicides, there are some weed/grass killers that can work for about a year.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by crek31
    So did you figure out what you wanted to do? How's it going -- any new pics? I'm struggling with what to do in our yard as well, so I'm trolling for before/afters.
    Additional comments have been moved to new topic.
    See http://www.troublefreepool.com/lands...as-t15711.html for a very long post I replied to the original poster. Too long to repost.
    Anonapersona
    11,969
    Sorry, I thought your post was to Crek31. I'll copy it and post it for you.
    11,969
    Quote Originally Posted by anonapersona
    Fro several years I did landscape designs, so let me help you get started. First, get the survey of your property that you got when you bought it. Do your best to get it blown up to a size of 8' or 10' per inch, if you have an office copier that will adjust magnification or can do that online. Otherwise, carefully draw lines every 10' on a copy of the survey and hand draw a larger version to work on onto graph paper. You can work with the original survey but it is a pain to work that small, usually something like 20' or 30' to the inch.
    On this working plan, lightly pencil in traffic patterns, utility areas, fences, hose bibs, electrical outlets, windows, doors, and where there are views you like or don't like, and sources of noise. Then, add in where the sun is in the summer and winter. Be sure to leave room for the dog to run along the fence, for the mower to get from here to there, for the grill and for storage of pool toys and tools. Best to just indicate vague circles for these areas and get specific later on.
    One of the most important things to consider is "Water in, Water out" so mark on the base plan the direction that water flows from the property as well as how you water the grass and how you will water the beds. You do not want to build over the swales that may exist that carry water from the back yard to the front, they may be subtle and easy to overlook.
    Also consider directions of prevaling winds in winter or summer. You may want to channel soft breezes that may come from the southeast and beware of deciduous trees that will blow leaves into the pool on winter winds.
    You ought to have a firm plan in mind for all the hardscape at the start, even if it takes several years to get it all in place. The order that things should be done is, plan, electrical, water system, hardscape, trees, beds, shrubs, flowers. Trees and shrubs are best to put in in late fall if possible, selection of shrubs and flowers are best in spring however.
    Be sure to work on the soil before putting in plants, you may need to add lots of ammendments and treat for weeds, all that is easier before the plants go in. It is actually best to put in watering system and beds, then mulch, then wait several weeks for it all to settle before adding plants.
    I would stay away from loose rock (any sort) as I find that it does not actually stop weeds unless you are in an arid area. Weed mats are mostly useless as weeds still grow in the dirt/mulch on top and some weeds like nutgrass can push right through. Weed mat either deteriorates too soon or not at all and is a bear to get past once it is under tree roots if it is still intact. Pavestone pavers with sand dusted in between is nice, flagstone with crushed granite is nicer, concrete can be stamped or stained or pressed lightly with leaves for an interesting look.
    As for exactly what to plant, that depends on what is successful in your area. Some parts of Texas have alkaline soil that is difficult. Tour some of the better neighborhoods and take photos of the plants you like, then go to the local nursery or Home Depot or Lowes. Even the hardware stores tend to have a specialist in the gardern area that knows the plants well.
    In general, keep flowers well away from the pool, deciduous trees as well. If you have raised planters, be sure they do not allow mulch to run toward the pool and beware of where the water drains. Know where the pool overflow goes and where splash occurs, some plants will not tolerate the chlorine and salt so well.
    On the plan, find out the mature height and width of each plant you like and draw a circle of that mature size on a sheet of tracing paper. Try to allow for 3 plants deep, but if the bed gets deeper than 5' you may need a path into it to do maintainence. Mix and match shrubs to fill the proposed beds, with some thought to what it will do in the winter, as well as mixing color and texture. Concentrate on shrubs, leave the flowers for last and in small doses of concentrated areas. Be very aware of what you will see from windows in the house and frame those views well while screening others as needed.
    I may be able to direct you to some good books on plants, but the more important part is the hardscaping which will depend on how you will use this area. So, concentrate on that first, as you are getting the pool into shape.
