Thread: Advise on Salt water Generator
    May 2016
    The Woodlands Texas
    2
    I have a zodiac lm 24-2 salt cell that no longer works. Not sure about control panel would only go to minium %output or superchlorinate system. What would you recommend for a new swg, have looked at hayward aquarite t9, and circupool sj20? I have a 15000 gallon pool with diamond brite finish.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Advise on Salt water Generator
    Welcome to TFP
    I love the circupool, they have worked very well for me and others but the hayward is also a great system... if you have hayward automation equipment stick with them, if not the circupool is great..
    We recommend going 2 to 3 times the size of your pool so the SWG will last longer and has to work less, just to give you an idea, I have 13000 gallons and have the RJ 45k (yes, I went big)
    So, the SJ 40 or the hayward T15 would be a great choice for you
    here is a comparison chart to look over and these guys are really great to buy from
    Full Market Comparison of Salt Water Chlorine Generators for Swimming Pools
    I hope this helps
    Jun 2011
    Long Beach, CA
    2,778
    Welcome to TFP!
    Both of those sizes are small and we recommend a 40,000 gallon rating for your size of pool. That would be either the T-15 or SJ-40.
    I'm partial to Hayward myself, but others like CircuPool.
