Thread: Pump question
    May 2016
    Hampton
    29
    Pump question
    Hey all. I'm a pool newbie so go easy!! I've got a 20000 gallon in ground 30 year old gunite pool. Here's is a pic of my pump and filter. Here are my questions. I'm running the pump 10 hours a day, 6pm to 4 am. This is my first full season with the pool and we pay .19 cents per kWh. What is my best option for a pump replacement? 2 speed or variable? Could I just replace the motor on my pump instead of the whole thing? All my plumbing is 1.5", is my pump oversized?? Im just looking to easy the financial impact of running and maintaining. I am in southern NH and typically open mid to end of May and close beginning to middle of September.0529161449.jpg0529161445e.jpg
    20000 gal in ground gunite
    Hayward s200 sand filter
    Hayward 1.5up single speed pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,015
    Re: Pump question
    The easiest way is to reduce the pump on time. I get by with only three hours a day. If you have tiered rates, do your running during the cheap hours as much as you can. Just remember it has to be mixed well before testing and after adding.
    Pool School - Determine Pump Run Time
