Thread: Restarting a Slam
    Jun 2015
    Grand Prairie, Texas
    36
    Restarting a Slam
    Was out of town last week and with the storms of Texas I returned to a dark green pool again.... I measured my chemicals and here are the results
    Chlorine 0, CH 200, CA 0, TA 100 and pH 8.0.
    I have the acid to lower the pH but wanted to know if I need to raise my CYA from 0 before I start slamming. I looked at the Chlorine/CYA chart to figure out my shock level and the instructions read the lower the CYA the lower chlorine level needed bring to shock. The chart starts at CYA 20 shock level 10 but doesn't advise what to do if CYA is less than 20 or 0.
    Thanks
    21000gals/in ground/plaster/pentair pump
    Jun 2015
    36
    Re: Restarting a Slam
    CA above should be CYA 0...
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Zero CYA means shock level is 10 FC.
    You can go ahead and add some CYA to get to 30 or so and just assume it's all there and start targeting 12 FC.
    Jun 2015
    36
    Thanks.. headed to strlory to get a stabilizer
