Results 1 to 10 of 10
Thread: which bubble cover currently recommended
    Jul 2012
    Whidbey Island, WA
    397
    Good morning
    Lotsa bubble cover posts but
    is any the current favored? to reduce heat loss?
    Thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: which bubble cover currently recommended
    Most just say, 8 mil thin cover.. I went with the diamond cover (16 mil) and seems to be holding up fine, but it is heavy
    Amazon.com: 8 mil solar
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by cowboycasey View Post
    ok, got it thank you
    and then blue or clear?
    Jul 2013
    Fletcher, OK
    3,353
    I went with clear
    Jul 2012
    Whidbey Island, WA
    397
    nothing further
    read this to mean blue clear is a draw
    thank you
    Jul 2013
    Fletcher, OK
    3,353
    sorry, missed it
    I went with clear
    May 2016
    Troy IL
    476
    How important is it that these things cover every inch of water surface? I can't find one that will seem to fit without getting a giant one that costs a fortune. There is an 18' by 36' rectangle on amazon for $76. My pool is an octagon shape that is 19' by 27' at it's longest lengths. So I'd have 6 inches on each side uncovered.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    That size will work fine. I have 8mil, clear also just for the record.
    May 2016
    Troy IL
    476
    Cool, thanks! I want clear, but the blue one I'm looking at is so cheap. All the clear ones are more for some reason.
    From engrav's comment above, I was kind of under the impression that it doesn't really matter what color it is if you use it correctly. In other words, remove it in the morning when the sun is out, and put it back on when the sun goes down.
    Jul 2013
    Fletcher, OK
    3,353
    I keep mine on all the time unless we are swimming, I went with the clear so no idea on what type blue is...
