Results 1 to 15 of 15
Thread: Replaster to Start Next week - if it stops raining
    Nov 2015
    Carrollton tx
    451
    Waiting for check list from Romos
    I plan to use their recommended pool service guy for the first 2 weeks
    that way they cant say I screwed something up
    I know at some point Ill need salt
    And CYA
    Ill get some gallons of bleach
    What else ?
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a BaduŽ Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
    30,431
    Re: Replaster to Start Next week - if it stops raining
    Do you have one of the suggested test kits? Reporting your test results is the only way to get started.
    Nov 2015
    Carrollton tx
    451
    I have the test kit. Funny, should just make a robot, answer to every third post is "buy the test kit"
    What Im asking is what to expect
    The plaster hasnt been done yet
    The results today dont mean anything since the water will be drained
    30,431
    We don't know. That's why you see so much about the test kit. It's the only means of real communication you can pass to us. We don't want to guess what you might need....we would rather suggest what you really need.
    You can go buy borax for pH up or acid for pH down but you'll have to return one or both when you post test results. You can post a pic and we'll say it looks very nice but that's not very helpful.
    I am sorry you do not see that providing us with accurate numbers is about the only way we can have an opinion on your pool. Everything we teach begins and ends with accurate testing.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,579
    Please add the test kit you have in your siggy so we know at a glace you have one.
    You can and should test your fill water. That will help us get you started BUT it is all really going to depend on what your PB does and adds.
    Hopefully he will add the CYA right away.
    With it being new plaster you are going to needs LOTS of MA because new plaster=PH going up as it cures.
    Kim
    Nov 2015
    Carrollton tx
    451
    Kim
    its in my Sig - has been - ill bold it
    thanks for the predictions
    thats what i was looking for
    Ill test the fill water
    Jul 2012
    Tallahassee, FL
    30,579
    Doug, I see it now. I read your siggy a couple of times but I did not see it ummmmmmm can I blame old eyes? LOL I sure can see it now! THANKS!
    Let us know what your fill water tests at. Do not bother testing for CYA as that has to be added.
    Kim
    Nov 2015
    Carrollton tx
    451
    Interesting PH results from tap water
    see images
    guess why they are both accurate tests
    No chlorine at all that was detectable
    CH was 75
    TA 30
    Rain has stopped - lets hope next week dries some
    Jul 2012
    Tallahassee, FL
    30,579
    I don't know why they are both accurate tests but they sure are different!!! Fess up and tell the story!
    Kim
    Nov 2015
    Carrollton tx
    451
    One was hot one was cold
    I ran both tests twice
    Jul 2012
    Tallahassee, FL
    30,579
    How did you heat up the hot one and how did you cool down the cold one?
    What did your water test at right out of the pool?
    SO interesting how the temp changed the PH like that. I bet there is science to explain it! MATT, Oh MATT! This is one for you! (Matt is our science guy)
    Kim
    Nov 2015
    Carrollton tx
    451
    I just tested the tap water at the sink
    one test w cold running and one test w hot running
    Jul 2012
    Tallahassee, FL
    30,579
    ahhhhhh so the hot water one came out of the water heat! Neat stuff!
    Kim
    Nov 2015
    Carrollton tx
    451
    Interesting that the gas hot water heater somehow is significantly raising the ph
    the water wasn't really hot yet just run from the hot tap
    Jul 2012
    Tallahassee, FL
    30,579
    Think about this.........the water is sitting in the tank for a little while as it is heated. There is all kinds of stuff in the tank. If you have ever drained your tank you would have seen the "stuff". The action of the water coming into the tank (splashing) and the heating is what caused it I bet.
    Kim
