Results 1 to 8 of 8
Thread: How to Operate Plumbing
    May 2016
    Tulsa, ok
    49
    Can anyone tell by looking at this picture how I am supposed to backwash? I assume the knob on the pipe that says "backwash" gets pulled out/up?
    Pump pressure is sitting at about 22psi.
    ~17k gallon, plaster/gunite pool, Pac Fab Challenger Pump 1.65HP, Sand filter. Rheem Heater. Waterfalls with 1 hp pump. Main Drain and 1 Skimmer.
    TF-100XL test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,025
    Re: How to Operate Plumbing
    You got it. A whole bunch of really filthy water is gonna come out somewhere. It may be hard-plumbed into a sewer or there could be a barb for a backwash hose, or you may just end up standing in mud.
    May 2016
    Tulsa, ok
    49
    Thanks Richard. Should I turn the pump off before moving any valves or switching to backwash?
    TF-100XL test kit
    Richard320's Avatar
    Jan 2010
    19,025
    Yes. If you try pulling that handle up with the pump on, you'll probably dislodge one of the internal O-rings and create all kinds of problems.
    May 2016
    Tulsa, ok
    49
    Ok. Sounds good. The backwash pipe goes into the ground, so I'm going to assume it goes to sewer. Can I vacuum to waste by having this open and then vacuuming?
    TF-100XL test kit
    Richard320's Avatar
    Jan 2010
    19,025
    Quote Originally Posted by Cmasty View Post
    No.
    All you're doing is reversing the flow through the filter. Waste takes the filter right out of the equation. If you vacuum on backwash with a sand filter, all the sludge will end up inside the standpipe and laterals and when you go back to filter, it will blow it back into the pool.
    You'll just have to vacuum then backwash.
    Apr 2013
    Sacramento, CA
    2,769
    I would make no assumptions.
    Richard320's Avatar
    Jan 2010
    19,025
    Quote Originally Posted by gwegan View Post
    That's actually a very good point. The previous owner of my house ran a white PVC pipe (oops, not to code) underground and up and over the garage door until it came out in a planter where there is sewer access. The pool guy said it never worked right -- too much backpressure and it flowed faster than the sewer would take it and overflowed all over the driveway, carrying mulch and everything with it. The pipe's still there, broken off flush with the ground.
