Thread: wanting to add pool info
    May 2016
    Castaic, CA
    2
    Angry wanting to add pool info
    I am new to this site. So far love it. But one thing, I can't seem to find the area to put in my pool info. I have read the two posts below and I am still unable to find an area that will allow me to enter any info on the pool. Please Help.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,031
    Re: wanting to add pool info
    Hi Motorcowboy,
    Welcome to TFP! I can help you with where to edit your signature.
    Just under the Pool School button, click on "settings". Then on the left side of the settings page, scroll down until you see 'edit signature' and click that.
    Then type in your signature info and click the Save Signature button.
    Hope this helps,
    Divin Dave,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Click this.
    Signature
    Please put the following information in your signature.
    The size of your pool in gallons
    If your pool is an AG (above ground) or IG (in ground)
    If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    The type of filter you have (sand, DE, cartridge) and, if you know, the brand and model of the filter.
    If you know, please tell us the brand and model of the pump, and mention if is it a two speed or variable speed pump.
    Date of pool build/install, particularly important if less then a year old.
    What kind/model of water test kit you are using
    Other significant accessories or options, such as a spa , SWG, or cleaner
    Please mention if you fill the pool from a well or are currently on water restrictions
    Please keep your signature to 5 lines or shorter. Everything above can be stated quit compactly. For example:
    19K gal, IG vinyl, 1/2 HP WhisperFlo pump, 200 sqft cartridge filter, AutoPilot Digital SWG, Dolphin Dynamic cleaning robot
    And welcome!
