Thread: Test Kit comparison table-TF100 no longer contains CYA Standard
    pookiesunshine's Avatar
    May 2016
    Cincinnati, OH
    424
    i guess this is extra now, have not checked.
    30000 gal inground vinyl liner;sand filter w/glass media, nuvo uv, TF-100 test kit; 25 years on Baquacil, converted to TFP chlorine in 2016
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: Test Kit comparison table-TF100 no longer contains CYA Standard
    Quote Originally Posted by pookiesunshine View Post
    Actually, your kit must be an older one. The newer ones, as of May 18, 2016 at 10 pm, have the standard. Hence the increase in price from $68 to $70.
    30,400
    A little mix-up here. There has never been a test kit available that contained the CYA standard solution. The TF-100 is the first one. It was added to the kit as a result of many, many members not being confident in their CYA results.
    Adding that test as well as price increases from our suppliers, changed the kit from $68 to $70. We thought the benefit of that reassurance test was a good value so all TF-100's forward will carry it.
    I am marketing here a little but let me say that we have created a 2 oz version of the Standard 50 ppm solution that you can order from TFTeskits if you feel you need that extra test.
    May 2016
    Cincinnati, OH
    424
    I was just pointing out the apparent discrepancy so someone could fix the table and avoid misleading someone. i got my kit from tftestkit.net in April ish. for some reason found myself back on the comparison page and noted the bolded cya standard. i double checked my kit and it was not listed. I thought it would be a bonus, but i'm not worried about it. My own tests have been verified by two different pool stores-one Leslies using the same type of test but a smaller test cylinder, and two, a disk/cartridge computerized test. No worries.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,383
    The table is current as of May. Thanks for making sure it was correct!
    Kim
