Thread: Switching to a SWG, are there pros and cons?
    Aug 2015
    Melville, NY
    9
    Are there any write ups on the pros and cons of switching to a SWG? I'm told the biggest advantage is that I don't have to constantly maintain the pool chlorine level. It's for our summer home which will save me the hassle of making weekly trips to the house in order to maintain the pool chemistry.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Re: Switching to a SWG, are there pros and cons?
    There are loads of threads on this site discussing just that if you search.
    If for a pool you aren't around every day as you mentioned, the only concern I'll mention is getting stable TA and PH. Many people have constant PH rise with a SWG. I personally do not. Once I get my TA in the 60-80 range at the beginning of summer swim season, I almost never need to adjust my PH with acid.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jan 2010
    Randleman,NC
    620
    So far so good for me.I love it.I test my water on Sundays.PH stays 7.5 Alk has been 80.Did drop to 70 this morning.Biggest thing my Chlorine level stays consistent at 7.5 Biggest breaker for me was the cost for sure.I finally bought one first of the year because it was a steal.Should have bought two for the price
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    I've never seen a thread asking how to program a bleach jug, nor asking what this light or this code means on a bleach jug.
    All the SWG eliminates is buying, carrying, and pouring bleach jugs. Everything else is the same with a SWG pool. Regular testing, pH adjustments, brushing, vacuuming, all the same. It's not set-it-and-forget-it.
