Thread: Polaris. How long to run it?
    May 2016
    St Paul, Mn
    30
    Hi
    newbie here...with a newbie question. My pool is 40 x 20 feet , 40000 gallons.
    i have a Polaris automatic vacuum and an automatic pool cover. Don't get a lot of leaves in the pool because I close the cover on windy days.
    My question is how often and how long should I operate the Polaris ? Do I run it everyday even if the pool looks clean ? Or do I run it only when it looks dirty? And how long do I run it ?
    thanks
    40000 gallons, IG, Vinyl lining, Hayward sand filter 300 lbs,Hayward vari-flo xl valve, Hayward Super pump 1.5 HP, automatic cover
    30,431
    Re: Polaris. How long to run it?
    The seemingly smart-'** answer (but it's the truth, really) is as long as it's needed.
    I would start with three hours and then go up or down depending on your results. I would also start with every day and then moidify thaqt oif needed. Each pool is different and you will soon learn what your pool needs.
    May 2016
    St Paul, Mn
    30
    Thanks
