Thread: Cork in Laars lite Plug Hole
    I noticed an old post where @CUTiger78 suggested a cork for a worn out plug hole.
    I tried it with a cork one size too small and it partially broke and is pushed into the heater
    Do I need to have someone open the heater and locate it or what will happen if I leave it? (The cork piece that fell in is around 1/4" x 1/4")
    Attachment 49014
    30K Gallon Vinyl Inground
    Jandy DEL 48 DE Filter
    BBB Method
    Taylor FAS-DPD Test Kit K-2006
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Cork in Laars lite Plug Hole
    I would think a piece of cork that size would make it's way out of the heater and into the pool. Have you spotted it yet?
    Isolated Spa - 345 Gallons
