Results 1 to 9 of 9
Thread: Water Bugs
    Oklapoolma's Avatar
    May 2015
    Northeast, OK
    36
    Question Water Bugs
    Being a pool owner for only one year now, I thought I would try to really stay ahead of my bleach this year to avoid issues with water bugs. I have even been dumping extra bleach; test and scrub, vacuum, skim daily (some of those several times/day).
    So why in good heavens did I just remove a stick bug from the pool yesterday (about the 4th one this season) and about 3 backswimmers this morning? I thought I had the 'food supply' issue under control and yet it's pretty clear my pretty sparkling blue water has hidden issues. On a positive note - I have noticed DRAMATIC improvement with little to no Boatmens. Last year they were my biggest challenge. I thought the backswimmers feasted on boatmen and the boatmen feasted on algae...I'm about ready to throw this pool in the garbage! LOL...
    My latest numbers are:
    FC - 8.5 / CC - 0
    pH - 8.0 (I have also been struggling with keeping my pH down...yesterday the calculator told me to add 27oz and yet this morning, we are back up to 8.0 again! Calculator now suggests adding 43 more oz of m. acid)
    CYA- 45
    TA - 157
    CH - 448
    Any input would be welcome
    "BOOMER!"
    •21,000 gallon inground gunite pool
    •Pentair-PacFab Triton II Sand Filter -TR100 •Pentair-PacFab Triton Purex Challenger 1.5 H.P. Single Speed Pump
    •Taylor 2006 test kit •Dolphin Nautilus-99996323
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Water Bugs
    SOONER
    I also had the exact same issues and some great person on TFP found that BioGuard Back Up works great at keeping bugs dead in pools, it takes the surface tension of the water so they can not float on the top and takes the air away for the underwater one's
    I used 1/2 bottle last year and killed all of them, this year they showed back up and poured the other half and all are gone again
    Amazon.com : BioGuard Back Up - Quart : Swimming Pool Chemicals And Supplies : Patio, Lawn Garden
    now let's get that PH and TA under control, follow this below to drop you TA and PH
    Pool School - Lower Total Alkalinity
    I hope this helps
    38,290
    Re: Water Bugs
    What is in the back up? Is it borates? If so, there are cheesier options.
    Jul 2013
    Fletcher, OK
    3,353
    Re: Water Bugs
    I don't think so, it's more like dawn soap (dawn soap killed them in glass also) but I really do not know what exactly is in it.. The OP said it worked and I tried it and killed them for the rest of last summer and up to April this year...
    here is the MSDS http://www.hydropool.com/downloads/M...ck-up-msds.pdf
    Oklapoolma's Avatar
    May 2015
    Northeast, OK
    36
    Re: Water Bugs
    Thanks for this, Cowboy! I replied to you yesterday but don't see my post :/
    I was saying that I had tried that stuff; the BioGuard, last year when my numbers where more outrageous than now and that out of desperation I will give it another shot The TA and CH are a pain in the backside but have both been much higher...a work in progress...
    "BOOMER!"
    Jul 2013
    Fletcher, OK
    3,353
    Re: Water Bugs
    No problem, did it work last year at all? within a day they are all dead in mine, really within 30 minutes.. I know about the work in progress, but once you get TA down it will be so much easier
    Oklapoolma's Avatar
    May 2015
    Northeast, OK
    36
    Re: Water Bugs
    Well then, Cowboy, and whoever else is interested; let me reply with my latest results as of today.... NO BUGS!!!! Not a one!! Whoop. Whoop!
    My numbers today are similar, however, note my TA is lookin' kinda saweeet!
    FC - 11 (Guess it takes living at about 11 to AVOID the BUGGIES - in my case anyway!!) Guns still there,
    CC - 0
    pH - 8.00 (Daily struggle to keep it down to 7.6ish) (Yikes)
    CYA - 40 (Likee like)
    TA - 130 (I'll TAKE IT)
    CH - 538 (Yikes)
    Off now to catch up on my Game of Thrones
    Quote Originally Posted by cowboycasey View Post
    Oh - and no, I did not think the BioGuard worked too hot last year, but then again my numbers were much worse. I will keep ya posted on the latest results!!
    "BOOMER!"
    Jul 2013
    Fletcher, OK
    3,353
    Re: Water Bugs
    keep up the great work, that TA is gettin there
    Apr 2016
    College Station, TX
    79
    Re: Water Bugs
    Following for the same problem. I've been at SLAM level for 3 days and just found a colony of young water bugs swimming around. I think they like the chlorine!
    I also read somewhere that putting a little dawn in your pool will do wonders for cleaning the surface of the water. All of the floating sunscreen goes to the sides and can be wiped up. If it kills bugs too that would be an awesome tidbit for the board.
    Intex 16'x32'x54" 17Kgal AGP since 2014. Sand filter, Hayward skimmer, home built 10'x15' deck and stairs, solar heater. High TA tap water, moderate rainfall, weekly use. Treated with 10% bleach, MA and some dichlor initially. Soon to add borates.
    Taylor K2006C
    Future projects - automatic chlorine pump, online pool sensors, better heater, IGP (maybe)
