I'm not worried either. after being on this forum for awhile, i find that many people worry over nothing.
I don't know how much the test strips are as far as a "pays for itself deal" goes. Nor do i know how long you have to wait to get a reading. Is it instant? When i say i like the meter better it's because of the wetness deal. I can't be with out a way to check. I've had mine for over 2 years and had to calibrate it once. You have to check them, but you don't always need to calibrate. If you can use a test kit, Calibrating is a snap. Changed batteries once too. But i use mine an awful lot.JasonLion said:The AquaChek salt test strips are by far the best choice for residential pool owners. The electronic meters have to be kept calibrated, which most residential users will not do, or they can be way off. The AquaChek strips are also more precise than all but the most expensive meters. The main problem with the AquaChek strips is that they can go bad if they get wet or are exposed to too much humidity.
Thats my thought. If you are going to buy a salinity meter or even a pH meter, then keeping it calibrated should be a routine thing. I use a pH meter all the time. I calibrate it evey couple of days and it fine. Same for a salinity meter. If you want to pay for one, then do it. Just know how to maintain it and use it properly. I dont see a reason to discourage anyone from buying a meter if they want to.Pool Clown said:. If you can use a test kit, Calibrating is a snap. .
