Thread: Chlorine levels high but no free chlorine
    May 2016
    Ri
    3
    Just opened pool a week ago. Last year never really got it 100% cleared up. Starting off the same this year. Blue but real milky. Water tested yesterday and chlorine level high, total chlorine high but free chlorine low. What is recommended to fix this???
    Chlorine 5.2
    Total Chlorine 4.7
    Free chlorine .85
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Chlorine levels high but no free chlorine
    Welcome to TFP!
    Our methods for fixing this is called a SLAM
    Can I assume you got that testing at a pool $tore? Have you added anything to the pool? If so, what?
    Support the site
    May 2016
    Ri
    3
    When we opened we added 3 lb bags of shock, a bottle of Algecide and a spring pill. Since then we have added a bottle of metal out (metal levels high due to we'll water fill), some alkalinity booster, PH boost and another bag of shock.
    May 2016
    Ri
    3
    Yes, testing was done at a pool store.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to TFP
    To take control of your pool you need a great test kit, the TF100 is exactly what you need, if a little green grab the XL option, also the speedstir is awesome and almost needed if your CH is high..
    Please fill out your signature, it will help us give recommendations for your pool Trouble Free Pool
    I hope this helps
    38,295
    Welcome to TFP!
    The path forward certainly needs to be an investment in one of the recommended test kits. And then adding only what the pool needs. I have no idea what half that stuff you added even is.
