Thread: Crystal clear water green tint
    May 2016
    Niles
    2
    Unhappy Crystal clear water green tint
    Every year I deal with this. Open pool crystal clear put hose in to fill with well water turn on filter pool turns a nice green-Agua tint but water is crystal clear. Added metal and stain remover. Been 3 days water is still green.
    Geanine22
    30ft round semi above ground pool.
    Well water liquid chlorine cartridge filter
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Crystal clear water green tint
    Hi, welcome to TFP! Please edit your signature to include information about the pool such as pool type (above ground or in ground), surface (vinyl, plaster, or fiberglass), size in gallons, pump brand and horsepower, filter type (sand, DE, or cartridge), filter brand and size, and any water features, cleaning systems, and if there is a spa (attached or detached). Also please include that you are on well water or under water restrictions if those conditions apply to your pool. It will show up at the bottom of everything you post and it is easier for us to help you if we don't have to search the thread for this information.
    Have you used any copper based algecides? Do you use well water to fill the pool?
    Love TFP? Become a
    TFP Supporter!
    May 2016
    Niles
    2
    Yes well water to top off pool. Don't know own about cooperating just added algacide from store
    Geanine22
    Jul 2009
    Houston, Texas
    9,376
    If you still have the container from the algaecide check the active ingredients. It should say whether or not there is copper in it. I would have a sample of your well water tested for iron. They can run this test at the pool store. If it is positive you will need to add and maintain sequestrant to prevent the iron from oxidizing and turning the water funky colors and staining the pool.
    Love TFP? Become a
    TFP Supporter!
