Results 1 to 9 of 9
Thread: Vinyl lining
    Feb 2016
    CYPRUS
    56
    Vinyl lining
    I help out at a dog rescue centre here in Cyprus, they have a 10 x 5 metre vinyl lined pool. The lining is bubbling but they do not have the money spare to renew the lining. You can peel the bubbled lining off and underneath it seems fine. Does anyone know of a way of removing this top layer of the lining or if there is a way to seal it.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Vinyl lining
    If the vinyl is bubbling and peeling it really should be replaced, then I have never seen a liner do what you are saying, could you post a picture for us?
    Feb 2016
    CYPRUS
    56
    Re: Vinyl lining
    Thanks for your reply but changing the liner at this present time is just not possible.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    Re: Vinyl lining
    Could you please post a picture. Vinyl liner do not peel. They are not layers of vinyl. I have an idea on what you are seeing but need to see a picture.
    Kim
    Feb 2016
    CYPRUS
    56
    Re: Vinyl lining
    I will get some photos tomorrow and post them up.
    May 2015
    Buffalo NY
    15
    Re: Vinyl lining
    I am going to guess that the liner either has a clear uv film that is pealing or that the printed pattern itself is pealing off of the vinyl. Probably no way to just remove it more than just pealing what loose or cutting it off to ensure its not ingested by a animal.
    40,000 Gallon Swimco vinyl liner inground pool, Hayward Perflex EC75, 3/4 hp pump, Jandy LRZ325EN gas heater
    Feb 2016
    CYPRUS
    56
    Re: Vinyl lining
    Unfortunately the pool had been filled before I could take any photos. Realdeal008 I think you are spot on with what you describe. All the loose material was either jetted or cut off, thanks for all the replies.
    10300 Gallon vinyl pool, 0.75 Kripsol pump, glass filter, Pool Exact EZ photometer tester.
    9500 Gallon vinyl pool, 0.75 Kripsol pump, glass filter, Pool Exact EZ photometer tester.
    Jul 2012
    Tallahassee, FL
    30,476
    Re: Vinyl lining
    Glad it worked out.
    Kim
    Feb 2016
    CYPRUS
    56
    Re: Vinyl lining
    Thank you, think this site is fantastic...
