Results 1 to 7 of 7
Thread: If this Shock Plus product isn't a sanitizer, what is it?
    Jun 2013
    Boston
    8
    I bought a box of Chlorox Shock Plus, active ingredient Sodium dichlor
    (like this: Clorox Pool and Spa Shock Plus, 12-Pack - Walmart.com)
    And I just finished using it for my pool opening which was battling massive algae, when I looked at the box and it said:
    "Not for use as a sanitizer or algaecide."
    I am waiting on a refill kit to test my other chemicals, but it indeed was adding chlorine (along with stabilizer I think so I'm switching to bleach as soon as I can). So what does that mean? Why would it say it's not a sanitizer
    Thanks!
    Kai
    18,000 Gallons - gunite pool, Pentair cartridge filters, skimmer-only (main drain busted), 400k BTU heater, 1 HP variable speed pump.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: If this Shock Plus product isn't a sanitizer, what is it?
    Well, this is what they say it contains:
    Sodium Dichloro-S-Triazinetrione 58%
    aluminium sulfate 7-13%
    Boron salt Trade Secret 7-13%
    We battle algae by conducting a SLAM
    For that you need a test kit to deliver measured doses of chlorine. Dumping in bags of dichlor untested would not be one of our recommendations.
    Support the site
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    882
    Until you can establish what your CYA level is I wouldn't be dumping any more of that dichlor in.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    That's a very good question. I have no answer for you. As far as I know, once dichlor is mixed with water, it releases Chlorine which is both an algaecide and a sanitizer. Maybe you should email Chloroxpools customer service and ask them what the stuff IS good for?
    Jun 2013
    Boston
    8
    Thanks for the responses, I'll keep using the liquid bleach I got until I get the tests refilled.
    May 2016
    Santa Cruz, CA
    1
    pool shock is most often Calcium Hypochlorite ...think of it as granular bleach...and bleach is the same thing as chlorine essentially, just a molecule off.
    The only difference between the pool store chlorine and your local stores household bleach, is the strength. Pool Store Chlorine is usually 10-12%, where as store bleach is 5-6% and the price is comparable. So you're better off getting chlorine.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Calcium hypochlorite has calcium combined with the chlorine.
