Thread: need to move filter and pump
    May 2016
    spencerport/ny
    1
    I am a new pool owner, I set up a 24 ft. round pool. I over looked the fact that my power source needs to be be buried 18 to 24 inches. The pool sits partially on my septic lines. I want to move the filter and pump approx. 15 ft from where it is now. My question is is it ok to have longer hoses ?
    Jun 2014
    15,205
    Re: need to move filter and pump
    Hello Mike and welcome to TFP. In most cases, pumps can support an additional 15ft with no problem. At some point, don't forget to update your signature with all of that pool and equipment info for us. Nice to have you with us.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Have you considered getting a few adapters like these and hard plumbing the extensions you need?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to TFP
    Most go to using hard pipe for longer runs, my equipment pad is about 25 feet from my intex pool my build thread below has everything I used to hard pipe the pool in
    How partially on you septic lines? I had to build on the side of my property because of the septic system taking 80% of my backyard..
    here is my thread on it AG pool over septic leach lines
    Casey's Avatar
    SW PA
    10,453
    Welcome to TFP
