I own the TF-100xl with SpeedStir and Taylor K-2006c
trevorfl
45
Orlando, FL
Hello. I was running out of some reagents for the Taylor K-2006. I decided that instead of ordering reagents for the Taylor kit I will order the TF-100. I did it. Some things are not the same but that is not the question.
The question is about both kits having the same reagents numbers.
Can I use the reagents that have identical numbers on any kit? (Some are not labeled Taylor but the reagent numbers are the same).
I know reagent R-0600 and R-0014 will be only for the TF-100. But am not sure about the rest. Not that I will use that kit a lot because here in FL I will maintain the CYA at 60 meaning I need to do a daily test with the reagent that give me the high readings.
Sorry if the question was ask before. I did a research but did not find an answer.
Can I use the SpeedStir to mix some Taylor-K2006 test?
Thank you in advance
The TF100 uses taylor chem's just a better amount for how we test TFP pools :)
you can use the speedstir on any of the tests, isn't it awesome :)
